Sponsored by: Kumho
wheel cyl replacement
Old Sep 10, 2011 | 12:16 PM
bamaf150's Avatar
bamaf150
Just replaced pads and drums on one side of rear on a '76 f100, got to other side and looks like a leaking wheel cyl. Question: do these need to be replaced in pairs; in other words do I have to tear down the side I already replaced to install a new wheel cyl even though its not leaking ;(?
Old Sep 10, 2011 | 01:28 PM
Lazy K's Avatar
Lazy K
No they don`t. A lot of guys would replace both on the assumption that if one is leaking the other may not be far behind but it is not necessary.
Old Sep 13, 2011 | 08:19 PM
elgemcdlf's Avatar
elgemcdlf
They are also replaced/rebuilt in pairs due to wanting even hydraulic effort on each wheel. In theory the new one will work more easily than the old one due to corrosion and weaker seals. Do you know what steer brakes are on a tractor? It is the ability to steer a vehicle with the brakes by applying to one wheel more than the other. If your wheels are not applying pressure evenly you can end up with a steer brake situation.
Old Sep 14, 2011 | 09:00 AM
andym's Avatar
andym
I would replace both cylinders for both of the above reasons. You don't have to tear everything down to replace it. Just remove the springs from the pin and move them out of the way far enough.
bamaf150
Sep 10, 2011 12:28 PM
Sparky83
Sep 4, 2009 09:49 AM
63trogan
Dec 5, 2007 04:32 PM
Dlobacz
Aug 26, 2007 07:15 PM
clev
Aug 12, 2006 07:38 AM
