new injection pump
Old Sep 10, 2011 | 12:04 AM
Deereguy90's Avatar
Deereguy90
Arrow new injection pump
i got a new injection pump that i am going to put in my 1987 f250 6.9 how do i make sure the time is right?
Old Sep 10, 2011 | 09:11 AM
farmert's Avatar
farmert
To time it right you need a meter. If you line up the mark on the pump and the one on the gear cover, it will be close enough to start and run to take it to someone who has the meter. You can time it by ear, meaning when it is cold and you first start it, it will have a "powerstroke" rattle to it untill it warms up and the timing advance kicks off. When the advance kicks off it will run a little quieter.If you don"t hear the rattle when cold, advance the pump by turning the pump so the line moves towards the passenger side. Do all timing adjustments with the motor not running. You do know the correct way to change out the pump don"t you? Do NOT remove the timing gear cover.
Old Sep 10, 2011 | 06:39 PM
knoxvegasdaddy's Avatar
knoxvegasdaddy
I'm doing the same on a 91 7.3 as part of a rebuild. Is the "Y" mark on the cam gear and injector pump gear what I want to line up?
Old Sep 11, 2011 | 11:09 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
https://www.ford-trucks.com/forums/3...ml#post9927448
when dissembled properly,you won't be dealing with those marks.
TikiWiki : IDI Fuel Injection Servicing
oh.your doing a rebuild.my bad.
make sure you follow this:
http://www.members.shaw.ca/k2pilot/Timing%20article.htm
Eallend7
Aug 14, 2013 04:01 PM
daleyboy
Mar 18, 2013 10:53 AM
deerhunter9309
24
May 5, 2010 02:43 AM
twfs
Apr 26, 2009 01:36 PM
eiznekcm
Apr 19, 2001 11:49 AM
