injection pump
Old May 1, 2010 | 01:18 AM
deerhunter9309's Avatar
deerhunter9309
Exclamation injection pump
So i just bought my first diesel. its a 7.3 nonturbo. the guy told me that it wouldnt make it around the block and well it didnt. he gave me an injection pump but I dont know if its just a key up and go like my buddys dodge or if u need to time the pump. Please let me know guys its my DD
Old May 1, 2010 | 02:34 AM
Sycostang67's Avatar
Sycostang67
When you install it and line up the timing marks, that gets it close enough to run but you will still need to get the timing properly set.
Old May 1, 2010 | 08:12 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
And follow the correct procedure to R&R the pump, so you don't loose the IP gear timing.
DO NOT remove the IP gear housing. (Where you add oil)
-Enjoy
fh : )_~
Old May 1, 2010 | 11:16 PM
Marianna2003's Avatar
Marianna2003
Check out this guy:
"Fuel injection pump adjustment article"
Sincerely,
Gene O
Old May 1, 2010 | 11:26 PM
rupejosh's Avatar
rupejosh
you can thank dave sponaugle for the instructions i cant take credit for it
On a NA engine, you should be able to remove the IP and all the injection lines as one unit.
Loosen all the nuts on the injection lines at the injectors.
Remove all three wire connectors from the IP.
Remove the throttle cable from the IP fuel lever.
Remove the supply line from the fuel filter to the IP.
Remove the return line from the IP.
Remove the throttle return spring.
Loosen the three nuts holding the IP to the IP drive gear cover.
Remove either the cover plate or the oil fill spout from the front of the IP drive gear cover.
Remove the three 5/16" 12 point bolts that hold the drive gear to the IP drive shaft.
Slide the IP straight back, finish removing the three nuts when you have enough room to turn them off.
Now slide the whole mess straight back while raising the rear of the IP.
It should lift right out.
Install, just start at the bottom of the list and go to the top.https://www.ford-trucks.com/forums/66...t-7-3-idi.html
Old May 2, 2010 | 11:03 PM
deerhunter9309
Thanks guys. we got it running last night. we found a guy that knew what he was doing and we called him and he helpd. now is there a high flow ip to throw more fuel or is it impossiable to make these trucks smoke
Old May 2, 2010 | 11:18 PM
oreocreaming's Avatar
oreocreaming
all you gotta do it turn up the pressure on that pump. theres a port on the passenger side of the pump. inside theres a allen screw. just turn it one flat and you'll see some smoke.
Old May 3, 2010 | 04:53 AM
mistakenID's Avatar
mistakenID
It's certainly possible to make a whole lot of smoke with an IDI but why would you want to, especially with fuel prices on the rise again and EPA clamping down. You might as well throw dollar bills out the window while you drive.
Old May 3, 2010 | 07:16 AM
deerhunter9309
do th 90' f250's look better with a stack??
Old May 3, 2010 | 08:26 AM
johnboggs21's Avatar
johnboggs21
personally I think most all look better with stacks.
Old May 3, 2010 | 11:26 AM
deerhunter9309
k guys im lookin to make this truck smoke as much as possiable where do i start
Old May 3, 2010 | 01:39 PM
Festus Hagen
Methanoholic
What for ... to bring the envio ****'s down on us, to waste fuel or just to think you are cool!
Those in the know, know that smoke ain't cool, it's ignorant!
That said, On the right (passenger) side of the IP is a triangle plate, remove it (catching the fuel), turn the motor until you see the allen screw, turn it in ... Go for a ride and be cool ... In ignorant eyes.
If you don't have a pyrometer pray to your favorite god you don't melt it down!
-Enjoy
fh : )_~
Old May 3, 2010 | 01:47 PM
rupejosh's Avatar
rupejosh
why do you want it to smoke as much as possible.all that sokedoes is give you really poor mileage and high temps.if you want to roll coal everywhere plan on swapping motors all the time.if your looking to just look cool and try to look like a big drag diesel you might be asking advice from the wrong group of guys.these trucks are not going to be big fast drag trucks but they will work hard.they are built to be work horses not speed demons.the most you will get out of and idi will be a little over 300 horse is my guess.
Old May 3, 2010 | 01:48 PM
johnboggs21
If your gonna play with the fuel screw, for gods sake put in a pyro first. Its not that hard to do, and itll save you from melting holes in your pistons. Im putting one in mine sometime this week and then ill turn the fuel up just a hair. Im N/A, but i get NO smoke under heavy acceleration, so im going to turn up 1 maybe 1.5 flats and see how she feels then. I dont want to lose the pretty good mileage Ive been getting. Considering advancing the timing a little bit. I heard that its supposed to help some with the ULSD that the stations sell today.
Old May 3, 2010 | 01:54 PM
Festus Hagen
Methanoholic
Advancing the timing without the proper equipment may very well cause it to be worse off, proper timing is critical.
-Enjoy
fh : )_~
