injector question runs rough
Old Apr 14, 2010 | 06:11 PM
fixitman1310's Avatar
fixitman1310
hey guys i have 96 f250 ps 144,000 miles. new fuel pump.
fuel pressure 55 at regulator. new ipr,icp ,glow plugs.
new oil and filter. no fuel or oil leaks. truck starts right up
but has a miss. new cam sensor as well. how do i check
injectors. what is easiest way to test. thanx for any help
steve n.carolina
Old Apr 15, 2010 | 06:20 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
Steve,
With a miss at idle, you can remove the valve covers first, then start the truck and unplug the injectors one at a time. The injector that does not make the idle change is the one not firing.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Apr 15, 2010 | 03:37 PM
rideracelivemx7's Avatar
rideracelivemx7
a faster way of doing that is warm up the truck real good, then take off one valve cover at a time and look at each injector, theres a little deflector that oil will lightly squirt out of, if theres no oil then the injector is dead. but i dont know how bad your miss is, a dead injector or a not healthy injector. i personally just dont like unplugging an injector while its running, sketchys me out lol
Old Apr 15, 2010 | 07:12 PM
fixitman1310
thanx alot guys i will try that this weekend
Old Apr 15, 2010 | 07:43 PM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
An injector can still spit oil but not fuel, so that's not a real good way to test it.
There's nothing wrong at all with unplugging the actual injector...
__________________
Dan92
Feb 22, 2017 03:14 PM
dyoungen
Jan 27, 2017 01:56 PM
MONAVIERONJON
26
Jul 20, 2016 01:09 PM
JE917
Jan 4, 2011 06:18 PM
jrahn
Apr 12, 2004 08:20 PM
