06 F-150 window problem
Old Sep 9, 2011 | 04:28 PM
ocastellan's Avatar
ocastellan
I can't figure out how to open the door panel driver side.
Old Sep 9, 2011 | 07:16 PM
truckn1's Avatar
truckn1
I think if you do a search on here ,there have been threads on just that subject.
Old Sep 9, 2011 | 08:35 PM
Jake_f16's Avatar
Jake_f16
To take the door panel off you have screws on the bottom, behind the speaker panel and if you have electric windows pop that panel up and there is a screw there and also behind the little rectangle panel behind the inside door handle then just lift up and out on the panel and it should come off.
Old Sep 10, 2011 | 02:57 PM
ocastellan's Avatar
ocastellan
thanks I did not realize the speaker panel
Old Sep 11, 2011 | 01:54 PM
hotairgypsy's Avatar
hotairgypsy
easy stuff...just do not force stuff...you dont want to break the clips the panel uses to hold to the door
Old Sep 19, 2011 | 08:54 PM
ocastellan's Avatar
ocastellan
My regulator broke a cable
Old Sep 20, 2011 | 11:24 AM
gpeade's Avatar
gpeade
Ha Ha Ha
Join the club my friend. I have had to replace 3 of my four. Do a little searching here and you will find that many of have to replace them. Its an easy fix it's just expensive
bassin99
Nov 7, 2008 09:17 PM
fordordie
Mar 2, 2008 11:23 AM
Bigredtruck1
2004 - 2008 F150
May 16, 2006 11:17 AM
JJFL99PSD
May 4, 2004 03:09 PM
g0d
1997 - 2003 F150
Jun 10, 2003 11:55 PM
