Power windor/door panel
It's been awhile since I removed the door panel from my 1988, but basically. Look for any screws, I think there is one or two near or above the arm rest. There MAY be some smaller screws near the bottom of the panel, not sure. After you remove any screws, there are clips near the outer edges of the panel that just pop out and stay in the panel. Take a flat screwdriver and get under the panel as close to the clips as possible(yhoa you can't really tell where they are) and pop them loose one at a time. Hope this helps.
FWIW....they sell a special tool...kind of a forked flat blade..."trim panel removal tool" that does a much better job of removing the plastic clips without damaging the door panel or breaking said clips. They run around 7 bucks for a pretty good one and are available at most auto parts stores.
USMC0351fordtruckin
10-06-2011 08:02 AM
