2001 f250 WITH V10 WANTS TO DIE WHEN SHIFTED INTO REVERSE
I have a 2001 F250 with the v10 that wants to die when shifting into reverse. It doesnt happen all the time but getting worse. It has also done it shifting into drive a couple times or coming to a stoplight it wants to cut out. Reverse is the worse. Please Help
I can't help you but I had a 95 F350 with the 460 motor and mine did the samething that's why I have the 02 F250 now lol
Check the transmission fluid level. Low fluid can cause the torque converter clutch to drift on and cause a stall. It can also be a loose/missing internal filter, worn seals, or a worn pump in the trans. It could also be totally engine related, but I'll be not.
Mark,
So would those conditions cause TC lockup? I know zero about autos, but it sounds like the OP is experiencing TC lockup?
Yes, that's what I said. Any of those things can cause the torque converter clutch to partially apply, locking the torque converter. That causes the engine to stall.
Hi, I have a 2000 Ex with the V10 at 285k. Even with regular fluid and filter changes it just started having this same problem. I am wondering if anybody has fixed this issue with their vehicles. Thanks
