Update on Third Brake Light
Old Sep 9, 2011 | 07:08 AM
Coskid's Avatar
Coskid
OK maybe the two dealers I called are blowing smoke up my *** but I wanted to share this will you all anyway. My light started leaking recently and I was planning on just buying the new gasket from Ford as someone had said you could do for about $40. Well first off it was a whole new light with the gasket but hey $40 isn't so bad. Except they have changed the light around some and its no longer available at the $40 price it is now $81. So if you plan to change this out I would contact a dealer now or go straight to aftermarket as you can get a spyder LED for about $73 from autoanything.com. You may have better luck then I did and the dealer may still have one of the old lights in stock but just wanted to share.
Old Sep 9, 2011 | 07:14 AM
MCDavis's Avatar
MCDavis
Run a bead of silicone on that SOB Drew...that is unless it's cracked.
Old Sep 9, 2011 | 01:42 PM
Coskid's Avatar
Coskid
Shhhh! The wife might be looking at this and that would ruin me getting the smoked brake light to match my new smoked cab lights. No I thought about the silicone and yes you can do that but I talked to someone I trust who advised me to stay away from silicone on automotive paints unless you are sure where you are caulking will be hidden. So I am looking into the other options and while the $40 I liked the other numbers I am not so keen on at the moment. But I did contact a dealer today who told me they had the light for $63 so that's better then the $81 from the other places.
Old Sep 9, 2011 | 01:50 PM
MCDavis's Avatar
MCDavis
Drew, FWIW, Richmond Ford gave me a deal when I needed the driver's window switch. The price difference between retail and Ed (partsguyed) was about $35 and Richmond was compliant and met me in the middle. Would have been about the same amount as Ed + shipping and I had it same day.
Old Sep 9, 2011 | 02:33 PM
ChrisCarter's Avatar
ChrisCarter
Does the dealer carry smoked lights?
Old Sep 9, 2011 | 02:50 PM
Coskid's Avatar
Coskid
Chandler I talked to Richmond Ford as well as Universal and they both told me the same thing $81 for the new design light. Medlin Ford in Westpoint told me the $63 but then i either have to drive down or get it shipped.
Chris, No Ford doesn't have a smoked one that is an aftermarket product but it is an LED brake light and only $73 so when you factor everything together the aftermarket is the best deal currently because it will have free shipping.
Old Sep 9, 2011 | 02:54 PM
MCDavis's Avatar
MCDavis
Will Richmond or Universal match Medlin's price?
SuperDutyScaler
2004 - 2008 F150
Jan 5, 2017 02:32 PM
DattMavis
Mar 14, 2015 02:14 PM
bmvtr
2004 - 2008 F150
Jun 4, 2010 08:17 PM
offrdmania
Jan 23, 2010 07:03 PM
CZorn25
1983 - 2012 Ranger & B-Series
Jan 22, 2003 10:55 PM
