HPOP options
Old Sep 10, 2011 | 10:01 PM
  #31
WA.Ranger's Avatar
WA.Ranger
Originally Posted by joeyd61
Ok, here is what i have,there are 3 runs in the 120 race tune..
OIL TEMP 141 ICP MAX 2565 IPR 35.98
156 2932 44.14
186 2789 49.22
The runs are 45-90mph....even though these numbers look good,and the truck is still climbing speed,the oil pressure is droping..I know DP detunes the truck when cold,though not sure where it changes....I will say these numbers are better than the first two which,the 1st at RRE was 2200psi in 120race,the second appx 3 weeks later and it was 2400psi..the difference is at RRE the runs were appx 3-5 miles wot runs on the interstate, the others are 45-90mph runs and off the pipe..I read somewhere to test the HPOP is wot for 10 minutes in park..Na, i dont like that idea....
Joey, to answer your question, no, 85e is my strongest tune....
Thanks for your help...
oh and at idle ICP 480 IPR 9.77
IIRC, I think it's at 160*
Old Sep 10, 2011 | 10:28 PM
  #32
joeyd61's Avatar
joeyd61
Originally Posted by F350-6
Like Curtis said. Your IPR is not maxed out. That means you could get more ICP out of your current HPOP if the PCM called for more pressure.
Originally Posted by Pocket
Your IPR duty cycle is not maxed out there. Is that the highest it reaches?
Originally Posted by bulla
Exactly. When I thought I was having hpop issues my icp was around 1800 and dc at 97-98%. With my "new" stage 1's I get 2800-2900 in 120 race and 45-50% dc. With my original pump.
ok,so is it in the tuning????spoke with Jody at RRE and he says not enough oil,that is why the testing started.....
also will that explain why the oil pressure drops????
Bulla, are you holding that pressure????Isnt that close to what i am seeing
oil temp 186f ICP 2789 IPR (dc) 49.22...these are max numbers and ICP starts droping from there.....oh and in the 120 race tune....
Old Sep 11, 2011 | 10:58 AM
  #33
bulla's Avatar
bulla
Yea thats about right. So why did you think it was only holding 2200? Was the truck completely warmed up that day?
Old Sep 11, 2011 | 11:24 AM
  #34
joeyd61's Avatar
joeyd61
because thats where it leveled out at at RRE....yes it was warm,
Old Sep 11, 2011 | 11:36 AM
  #35
bulla's Avatar
bulla
Humm...... Not sure why it would change from then till now. Didn't you dyno?
Old Sep 11, 2011 | 12:52 PM
  #36
joeyd61's Avatar
joeyd61
yes---318hp 550tq, but i dont remember how warm the truck was....so that may have been before it got up to temp,i dont remember....hence, the testing..
Old Sep 11, 2011 | 01:55 PM
  #37
bulla's Avatar
bulla
I don't want to sound confusing but your wot on the interstate, can you explain ? When I have tested mine it is normally in od with my foot on the floor but never past 90.
Old Sep 11, 2011 | 09:14 PM
  #38
bulla's Avatar
bulla
https://www.ford-trucks.com/forums/s....php?t=1098081
Old Sep 12, 2011 | 01:06 AM
  #39
TerminatorEng.'s Avatar
TerminatorEng.
Joey, but didn't you still have temp issues at RRE?
The data logs I seen, looked decent. Yes, your DC is not maxed out.
farmb0y
20
Aug 28, 2022 08:53 PM
JOHN2001
Oct 31, 2011 04:13 PM
hedhntr
Dec 28, 2010 08:57 PM
7.3 Rocket
Aug 9, 2010 09:44 PM
jchosler
114
Jul 19, 2010 01:18 PM
