terminator modded pump
Old Dec 27, 2010 | 09:53 PM
hedhntr's Avatar
hedhntr
What injectors can i run with joeys modded pump, is there a limit say stage 1 or 2 or will they run everything? Im wanting to send in my hpop off my 97 so i can get bigger injectors. Thanks
Old Dec 27, 2010 | 10:39 PM
oldbird1965's Avatar
oldbird1965
I know they will run two's, some one else will have to come along to answer above 2's.
Old Dec 28, 2010 | 09:16 AM
Talyn's Avatar
Talyn
The modded 17 will easily run 2's.
Some of the bigger suckers like Bcodes wont be ran by just 1 modded 17 though.
I'll forward this to joey.
Old Dec 28, 2010 | 11:09 AM
Brown Falcon's Avatar
Brown Falcon
Yeah, 2's for sure. Probably not 3's or bigger, you'd need dual pumps or a much stronger pump than just a modded 17*.
You'd be able to run hybrids as well because they use less oil than single-shots.
Old Dec 28, 2010 | 02:47 PM
TerminatorEng.'s Avatar
TerminatorEng.
Depending on the size of the stage2. Some 2's are 160-170cc, while others are 180+. If it's around 160cc's, it should be fine.
Thanks,
Joey
Old Dec 28, 2010 | 05:50 PM
hedhntr's Avatar
hedhntr
Joey is there a way i can contact you?
Old Dec 28, 2010 | 06:06 PM
427 fordman's Avatar
427 fordman
joey@terminatorengineering.com
send him an email, he'll help you out. Really good guy to work with
Old Dec 28, 2010 | 08:57 PM
TerminatorEng.
Thank you Darin.
gov2mod
46
Feb 17, 2019 01:26 AM
JWAbercrombie
19
Feb 8, 2013 04:08 PM
bulla
Nov 15, 2010 12:00 AM
powerstroked162
Apr 27, 2006 08:12 PM
gotgrouper?
Jul 30, 2003 09:54 PM
