Electrified Engine Block
Old Sep 8, 2011 | 04:42 PM
devilstone's Avatar
devilstone
Ok,
I have a 79 Ford F150 with a 460 in it. I just recently replaced the head gaskets and have put the engine back together. When I was reinstalling the distributor back into the motor I noticed a large amount of small sparking going on inbetween the engine and the gear/shaft of the distributor. This is with the battery hooked up.
When I attempted to start the vehicle, the engine cranks fine but I'm getting zero firing going on. I checked my coil, which was reading fine (replaced it anyways), and my Ignition control module (also reading fine, but replaced anyways).. I've pulled my distributor out to double check the whole sparking with the engine body and dizzy gears.. still happens.
When I disconnect and reconnect my positive battery terminal with a spark plug light tied inline with my coil wire/sparkplugs the light lights up on the connection with the battery but not when trying to start the truck...
I've checked my positive and negative terminals and major wiring 100 times over for pinches, busts, corrosion and bad connections... and I'm at a total loss...???
Has anyone ever run into this type of thing? An electrified engine block, or maybe my distributor is making some sort of short circuit inside? is this possible?
Any help or suggestions is greatly appreciated at this point.
Thanks everyone,
Devilstone
Old Sep 8, 2011 | 05:16 PM
NW 150's Avatar
NW 150
wow never heard this one before....good luck lol hopefully someone will come along with some suggestions or thoughts
Old Sep 8, 2011 | 06:25 PM
evam350's Avatar
evam350
Only thing I could suggest is to try another battery?
Old Sep 8, 2011 | 06:42 PM
devilstone's Avatar
devilstone
I've tried it with 3 batteries up till this point, same result on each battery. I've got 3 mechanics scratching their heads too...
Old Sep 8, 2011 | 09:04 PM
ford390gashog's Avatar
ford390gashog
You have both small wires connected on the correct terminals on the starter solenoid?
Old Sep 8, 2011 | 09:06 PM
mikeo0o0o0's Avatar
mikeo0o0o0
My guess is the sparking is caused because untill the distributor is firmly installed and seated the only electrical ground it's getting is where the gear is touching metal.
Be sure the coil itself is grounded then my next guess would be the pick up coil in the distributor.
A distant possibility would be the reluctor, that's the magnetic wheel in the distributor that's under the rotor.
Old Sep 8, 2011 | 10:45 PM
starwriter's Avatar
starwriter
Silly question but is the ground strap for your engine hooked up to the chassis?
Old Sep 8, 2011 | 11:14 PM
WeedStudent's Avatar
WeedStudent
I agree. I has similar issues with a chev I had back in the day. The ground wire that connected the block to the firewall wasn't hooked up. (it attached to the head and was removed to replace the head gasket). As soon as I hooked it up I had spark again.
lurch460
Jun 26, 2010 06:12 PM
Crimson
1983 - 2012 Ranger & B-Series
Jan 10, 2010 05:52 PM
mickman
Nov 5, 2009 11:34 PM
andym
1978 - 1996 Big Bronco
Jan 24, 2004 05:14 PM
dd1120
Jul 23, 2002 12:00 AM
