1978 - 1996 Big Bronco
non-starting Bronco
Old Jan 5, 2004 | 08:07 PM
andym's Avatar
andym
non-starting Bronco
Ok, this one's a goodie. I'm hoping someone has run into this.
The Bronco in my sig has an electrical short. Any more than a couple days, and the battery's dead. It has been sitting for a couple weeks now. I tried to start it today, and the battery (as expected) was completely dead. Not even enough to light the interior lights. I tried to jump it off my F-150. It came alive when the cables were hooked up, but it still wouldn't turn over. I tried to crank it, and it just buzzed at me. I couldn't tell where the buzzing was coming from. It sounded like down low on the passenger side in the engine bay.
The lights dim considerably when it's trying to crank. Recently, I bought a new battery for it, had the starter tested, replaced the solenoid, and replaced the battery cables with 4 gauges cables.
I don't know what else to check - I've replaced anything that has anything to do with the starting system!
Any ideas?
Old Jan 5, 2004 | 08:24 PM
BroncoRoadKill's Avatar
BroncoRoadKill
hook a multimeter up between the neg. battery terminal and the battery. Then start pulling fuses one by one untill the draw goes away.
Old Jan 6, 2004 | 01:07 AM
andym's Avatar
andym
Right..... But that doesn't fix the fact that it doesn't start.
That is a good idea, though.
Old Jan 6, 2004 | 07:05 AM
fcarruth's Avatar
fcarruth
The reason that he suggested that you pull the fuses one by one is that you could determine what circuitry the short is in, if you do have a short.
Also, coil, cap, rotor, plugs, plug wires, distributor TFI module and a few others all can play a roll in the starting of your vehicle.
Keep us up to date.
Worse case, get a local mechanic to check it out for you.
Old Jan 24, 2004 | 05:14 PM
xbigbronco's Avatar
xbigbronco
Bad ground?? mines doin the same thing...
Woodyavins
Electrical Systems/Wiring
Jul 16, 2013 07:04 AM
dangitsbrandon
Jul 15, 2013 03:08 PM
jamesbalnks
1997 - 2003 F150
Jan 7, 2013 07:58 PM
bburrito
Aug 18, 2010 07:42 PM
89KYBronco
Apr 2, 2009 07:18 PM
