seized 400 m
Old 09-07-2011, 07:51 PM
larcou's Avatar
larcou
larcou is offline
seized 400 m
I have rust scale so bad in my 400 can't turn engine to get to converter flywheel bolts. C6 tranny Any sugeestions or can I do it without turning the crank?
Thanks
Old 09-07-2011, 08:08 PM
mark a.'s Avatar
mark a.
mark a. is offline
Just pull the converter with the engine.
Old 09-08-2011, 03:14 PM
larcou's Avatar
larcou
larcou is offline
mark sounds simple enough. I have never pulled an engine with an auto trans. Sticks yes a few. I'm going to pick your brain if you don't mind? Guess I just remove the bell housing bolts and the inspection plate. That's all I know. Does the converter slide off a transmission shaft while still attached to the flywheel? And I guess I should be extra careful while sliding the engine forward up and out with the converter still attached. Any tips would really be appreciated. Thanks
Old 09-08-2011, 03:43 PM
Fordzilla80's Avatar
Fordzilla80
Fordzilla80 is offline
Yep, just the bellhousing bolts, the starter?, and the inspection plate. Make sure nothing else is connecting the transmission to the engine as well, and that nothing is keeping the engine in either. After that, just pull the motor forward.
Funny story, I actually just got finished pulling the C6 apart from my 300 I6 maybe half an hour ago.
Watch out for the trans fluid though, it may come out of the TC if you tilt the engine enough.
Old 09-08-2011, 04:31 PM
jeff14346's Avatar
jeff14346
jeff14346 is offline
my 390 was locked up, removed trans, took some time to remove converter bolts from flex plate, then from there started disassembly. ended up drilling the top of one of the pistons to help break it up, then big sledge hammer to beat the tops of the pistons, finally was able to rotate over, one piston had to be pushed out thru the bottom after crank was removed
Old 09-10-2011, 11:42 AM
larcou's Avatar
larcou
larcou is offline
Well off to harbor freight this weekend. Cherry picker, load leveler and engine stand. Then local Ford dealer for a motorcraft rebuild 400. Staying smog stock! BTW I'm in Topanga Ca. Anyone needs to borrow said items (of course when I'm done) let me know
Thanks for the tips.
Larry
Old 09-10-2011, 06:19 PM
Fordzilla80
Larry
Can I borrow the 400?
Old 09-10-2011, 08:45 PM
79superduty's Avatar
79superduty
79superduty is offline
WHEN PULLING THE MOTOR. JACK UP THE TRANS TIGHT AGAINST THE HUMP SO YOU MAKE ENOUGH ROOM TO PULL FORWARD.
Old 09-11-2011, 03:12 PM
larcou's Avatar
larcou
larcou is offline
sure the 400m is all yours just help pull and install the new engine...lol
Old 09-11-2011, 03:28 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,706 Likes on 1,393 Posts
Larry
Just a suggestion here regarding your motor. Not sure the Ford dealer will help you, as Ford has a habit of forgetting about older stuff sometimes.
Anyway, take a look at the printout from your last smog check. Note what your engine blew, vs. what is allowed. Could you blow more oxides of nitrogen? The compression and cam timing that saddles the 400 and 351m was intended to reduce those emissions. That said, if the standards are seemingly pretty high compared to what the stock motor produced, you may be able to gain some compression on the rebuild, and still pass smog. Just a thought.
taneum
19
01-08-2023 01:15 PM
sam-u-el
09-14-2013 11:06 PM
dobber97
02-11-2009 06:55 AM
bikesandcars
05-11-2007 11:12 AM
IceWagon
02-05-2005 11:23 PM
Quick Reply: seized 400 m
