Need help
Old Sep 7, 2011 | 04:42 PM
rangergirl94's Avatar
rangergirl94
Need help
Im trying to change my core suport and fenders how on earth do I remove headlights running lights etc im lost
Old Sep 7, 2011 | 05:05 PM
bashby's Avatar
bashby
What are you working on?
Old Sep 7, 2011 | 05:06 PM
subford's Avatar
subford
What is it on?
Year?
Model?
Old Sep 7, 2011 | 06:07 PM
rangergirl94
93 f150 4x4
Old Sep 7, 2011 | 07:13 PM
subford's Avatar
subford
Take a look at the Thread in the link below.
https://www.ford-trucks.com/forums/4...sasembely.html
Missing image in link:
Old Sep 7, 2011 | 11:23 PM
Beatertruck's Avatar
Beatertruck
The fenders are pretty straight forward after you get the grill and headlight support off. The trickiest part are the bolts hidden in the door jam between the fenders and doors. There is a factory foam moisture barrier in the gap hiding the bolts.
The headlight support has numerous bolts holding it on but the trickiest ones are in the lower corners of your engine compartment.
The passenger side bolts are way down in the corner behind you hornsThere are 2 bolts down there. Remove you battery and battery tray now to get to it(you have to remove the battery/tray to remove the fender anyways.
The drivers side hidden bolts are in the lower part just like the passenger side. Remove your air box and washer fluid tank/coolant overflow tank and bracket now(again, they have to come off for fender removal.
I just removed/replaced my fenders this weekend so the visions are still painfully clear
Here's a pic of mine with a fender off
bubbareitz
Aug 6, 2015 01:06 PM
BigF350
May 26, 2015 03:29 AM
cdmm151
2009 - 2014 F150
Oct 31, 2012 11:31 AM
empiretc
46
Mar 15, 2007 09:32 AM
keneboy
Mar 7, 2003 04:57 PM
