Daytime running lights
Old Oct 20, 2012 | 08:54 AM
cdmm151's Avatar
cdmm151
Can anybody tell me if the 2013 F150 that have the HIDs be programmed to have the daytime running lights like the previous models?
Old Oct 20, 2012 | 11:13 AM
shortride's Avatar
shortride
I'm not sure what you mean by "programed."
Old Oct 20, 2012 | 02:19 PM
Jus2shy's Avatar
Jus2shy
In Canada, our Halogen F-150's had their headlights run at reduced wattage to function as Day Time Running Lights (DTRL). However, the OP is wondering if the HID's function as the DTRL's or if there is some other lighting that picks up DTRL duty. I personally don't know the answer, but I know that it's just a programming tweak on the slightly older trucks to have the headlights function as the DTRL's. I don't know if they changed that to be the signal indicators or anything else.
Old Oct 20, 2012 | 05:57 PM
cdmm151's Avatar
cdmm151
I have had it done on my 2011 now I'm ordering a 2013 with hids.
Old Oct 21, 2012 | 01:18 PM
juneau76's Avatar
juneau76
Aren't HIDs full power or not power only? I'm thinking so, but that could be my inexperience talking.
Old Oct 21, 2012 | 01:25 PM
Jus2shy's Avatar
Jus2shy
You are right Juneau, HID's must have enough current to maintain an Arc inside the bulb/capsule. So they're either on or not. The reason why HID's are dim when they first turn on is because the mercury or whatever compound in the capsule needs to be melted and turned into a gas to convert more of the electrical arc to light. That's why I'm curious on how Ford handled the DTRL situation with the newer HID trucks.
Old Oct 21, 2012 | 07:03 PM
PrinceValium's Avatar
PrinceValium
Borrowed from another site:
The power-up of the bulbs happens in three phases. First comes the ignition, when a high voltage pulse is used to produce a spark which ionizes the Xenon gas, creating a tunnel of current between the Tungsten electrodes. After this comes the initial phase, when the temperature in the bulb capsule rises rapidly, the metallic salts vaporize and the resistance between the electrodes fails.
The ballast comes into function and automatically switches to continuous operation, when all metal salts are in vapor phase, the arc of light has achieved a stable shape and the luminous efficacy has attained its nominal value. Being supplied with stable electrical power by the ballast, the arc will not flicker.
Old Oct 28, 2012 | 07:02 PM
cdmm151's Avatar
cdmm151
I found out today from my buddy who has a 2013 said that the running lights are on through the parking light if equipped. That comes from the owners manual. So the question still remains is it programmable thing or is it something added at the factory for the Canadians?
Old Oct 31, 2012 | 11:31 AM
cdmm151's Avatar
cdmm151
Any Canadians out there have HIDs that can show us what lights up with DRLs?
Jus Cruisin
2015 - 2020 F150
17
Jun 2, 2016 10:07 AM
ol-blu
2009 - 2014 F150
Dec 11, 2013 06:54 AM
Shaggie
Aug 27, 2008 12:25 AM
JoeVB
Aug 8, 2006 08:07 PM
76Econoline
Aug 13, 2003 10:36 PM
