The thing running is the electric vacuum pump. It is trying to build vacuum but evidently has a leak. Is that line the one that goes to the water cutoff valve in the heater hose?
Did u install a program for the egr delete or did u have to leave the egr valve plugged up?
Thanks for the reply. The line goes from the mid of the passenger side air intake manifold to some sort of weird electronic device by the passenger side firewall.
I removed the egr valve and plugged it. It is not throwing a check engine light.
Move down to the 6.0 forum and re-post this. I am not 100% sure but I think that if u do not leave the valve plugged in, it will not run the fan and some other things. Post in there how u did the egr delete as well
