e40d problem
Old Sep 5, 2011 | 12:50 PM
schultzie78's Avatar
schultzie78
e40d problem
i have a 93 f150 302 4x4 e40d trans. the problem i am having is that the tranny is started shifting hard and when you hit about 35 mph or so the tranny like disengauges so to speak. the rps will rise but the trans is not engauged. fluid is fine color is good and not burned. i dont think the trans itself is the problem...im thinking it is a sensor... anyone have any info on this problem
Old Sep 5, 2011 | 01:00 PM
ymeski56's Avatar
ymeski56
Der Postmeister
A couple potentials. Do Error code scans!!!
Old Sep 5, 2011 | 01:03 PM
schultzie78
no check engine light is on and i did do a scan with my obd I reader and it turned no results....i guess i could try it again
Old Sep 5, 2011 | 01:28 PM
mox-ct's Avatar
mox-ct
I'm having the same problem with a 97 Power Stroke. Looking for answers too.
Old Sep 5, 2011 | 01:57 PM
rla2005's Avatar
rla2005
Please define the statement in bold. You should at least get the all clear of 111/111. If not you have a problem with your code reader, connections or PCM.
wardee
Bronco II
Jun 11, 2013 08:54 PM
renerider800
Oct 24, 2012 04:28 PM
jc2
Nov 29, 2007 07:36 PM
mtntop1
Jun 27, 2007 02:42 PM
wolson
1997 - 2003 F150
Sep 30, 2003 04:04 PM
