Sponsored by: Auxito
97 ford trans
Old Sep 30, 2003 | 09:06 AM
wolson's Avatar
wolson
97 ford trans
I have a 97 ford f 150 4x4 automatic trans that has 84,000 miles. when I am driving at roughly 35 mph it begins shifting but does not always complete the shift. It seems to flutter a little between the gears? If I accelerate it shifts with no problem but if I am driving in the 35 mph area it does not make a clean shift. HELP!!!! The tranny fluid has not been changed in roughly 25,000 miles. The transmittion code on the tag is U
Old Sep 30, 2003 | 02:30 PM
wolson's Avatar
wolson
I turned the O/D off and the problem goes away. What engages the O/D on this model trans?
Old Sep 30, 2003 | 04:04 PM
sowellcl's Avatar
sowellcl
Check some of the other threads in the forum. There's a couple that refer to a technical bulletin about a 2-3 shift problem in some trannys for the '97 or '98 F150. If the Overdrive "Off" light on the stick blinks, it's a warning code that something (either a sensor on the tranny or the tranny itself) is amiss. Check the other threads about transmission issues and I'm sure you'll find some useful information!
hamllik
Dec 30, 2013 12:55 PM
powerstrokediesel97
15
Aug 25, 2011 08:00 PM
khris
Mar 14, 2007 08:28 PM
Boa1277
Nov 12, 2005 11:00 AM
wolson
Sep 30, 2003 03:06 PM
