My Turn V's
Old May 5, 2012 | 11:45 AM
  #31
njneer1's Avatar
njneer1
looks good Sean. how much do you need to raise the rear?
Old May 5, 2012 | 07:47 PM
  #32
wpnaes's Avatar
wpnaes
The So Cal rake has grown on me... The used F350 rears are just sittin' waitin'... Plus, i really like gettin' her in the garage from time to time (1/2'' clearance).
Originally Posted by locknload223
I guess I'm confused. I thought leaf springs only went on one way.
You're right of course, but termn8rx asked, so I tried to answer.
Old May 6, 2012 | 10:13 PM
  #33
termn8rx's Avatar
termn8rx
Thanks again..Is the track bar the same?If not it will make a good club.. :-)
Old May 6, 2012 | 10:14 PM
  #34
termn8rx's Avatar
termn8rx
Also thanks to all those who posted Lie o meter.Fixed mine today.
Old May 6, 2012 | 10:56 PM
  #35
wpnaes's Avatar
wpnaes
No need to change this bar, it'll work fine with the new V or X's.
Old Feb 23, 2018 | 10:11 PM
  #36
Flyboy1100's Avatar
Flyboy1100
w/o looking at part numbers, is the bar the same as the F250, wouldn't raising the front shift the axle slightly?
Old Feb 24, 2018 | 07:51 AM
  #37
wpnaes's Avatar
wpnaes
Yes, the axle shifts slightly (1/8-3/8th of an inch?), but I haven’t noticed any handling changes.
Likely the same bar on an F250, those years with a Dana 50 on leaves, but not certain of that.
Old Feb 24, 2018 | 12:28 PM
  #38
Flyboy1100's Avatar
Flyboy1100
Thanks, jus starting to research this, front isn't sagging too bad, but big bumps bottom the front springs out, just looking for maybe 1-1.5" , nothing drastic, only plan to run 33's
Old Feb 25, 2018 | 11:06 AM
  #39
Flyboy1100's Avatar
Flyboy1100
just for kicks i did look, the track bar in year 2000 at least is all the same between Excursion, F250, F350, F450, F550. but I only checked 2 places online and only 1 of them even listed the part, the other shows it on the diagram but not in the parts list.
the year 2000 service manual says it is a 3B239, and that covers all Superduty's so maybe it is correct
Studawg
22
Sep 1, 2022 12:51 PM
1999SuperDutyStroke
May 27, 2010 10:44 PM
bczolone
Sep 2, 2007 08:46 PM
13MWZ
Mar 15, 2006 07:03 PM
hoxiii
Offroad & 4x4
17
Jan 10, 2005 04:15 PM
