Got out the tape measure and the level kit is only 1 7/8'' tall. Picture of putting them on the V leaves. Will do a bit more driving tomorrow to better assess.
Just picked up some v codes.The guy I got them from said they came off arch down not arch up like the factory x springs.When I swap them I put them arch down right.Also got the trac bar from the f250.Do I use it or is it the same?Hope it raises it up some.It is sitting only about a 1/2" from bump stop.Any input will help. thanks
The guy who sold them to you is confused. Mount them normally which is flat with the eyelets up. He thought they were arc down because they were de-arced at the rear of the spring when mounted. This is normal for stock springs. You cannot mount the springs upside down. If I read your post right?
Nice job! Not sure if anyone has mentioned it but doing one side at a time makes it easier to line stuff up.
I just took the blocks out of the my brothers truck to lower the rear a little. Power tool everything apart, power tool everything back nearly together then torque wrench the last few turns of the nuts. Had all 4 of his rear and front blocks changed out within 45 minutes including running a die down the U-bolts to clean the rust off the unused section.
Running a die down the bolts......
You are my hero!!!!!!
