HARMONIC BALANCER QUESTION ?
Old Sep 5, 2011 | 07:21 AM
1912barry's Avatar
1912barry
Originally Posted by MIKES 68 F100
THANKS , i'll switch it , came free with the valvoline 10/40 i bought .
If your gonna use Valvoline then use the VR1, unless you plan on putting a new cam in it after first run! VR1 has the more zinc for flat tappit cams.
Old Sep 5, 2011 | 08:39 AM
MIKES 68 F100's Avatar
MIKES 68 F100
adding trick flow break in , got the zddp covered
Old Sep 5, 2011 | 08:53 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
got my 67 tbird 390 together today and started disassembling the 360
i noticed the 390 harmonic balancer is thin like 3/8 or 7/16 with built in pulley groove. the 360 has a good 1" wide balancer with seperate pulley .
which do i use ? will the 360 work or will the balancer be wrong ?
352/360/390/410/428: There are two different harmonic balancers:
C3AZ-6312-E = 1963/67 352/390/410/428 / D5TZ-6316-D (replaced C8AZ-6316-A & D2TZ-6316-A) = 1968/70 428 (except 1969/70 S/CJ), 1968/76 360/390
360 introduced in 1968, used in F100/350's only / 410: 1966/67 Mercury Parklane only.
Outer pulleys for accessories (P/S, A/C, T/E, Dual Belt Alternators) bolt to the balancers, could have one, two, three or four sheaves (pulley grooves).
The A/T flexplate (C5AZ-6375-D) is the same: 1965/67 352/390, 1968/76 360/390 for Passenger Cars & F100/350's with FX & MX C-O-M & C6.
The 1965/76 352/360/390 M/T flywheels have the same applications as the flexplate.
There are two, because 352/360's (C5AZ-6375-K) have an 11" clutch on a 12 3/8" bolt circle. 390's (C5AZ-6375-L) have an 11 1/2" clutch on a 12 7/8" bolt circle.
But one can be used in place of the other.
Old Sep 5, 2011 | 08:02 PM
MIKES 68 F100
thanks for the help , i got the motor in today , just need to put the acessories on tomorrow .
pics
1968 f100 pictures by mikemstang66 - Photobucket
Old Sep 5, 2011 | 09:37 PM
Sleepy445FE's Avatar
Sleepy445FE
Looking good Mike! I like red ryder parts bin :P
It looks like you're planning on running dual breathers instead of a PCV system. I would suggest to change that passenger breather to a pcv and run to the carb. If not you'll be changing that thing left and right because it'll clog up fairly fast when used that way. JMO
Old Sep 6, 2011 | 08:56 AM
MIKES 68 F100
THANKS and thanks for the tip on the breather , got them on ebay for $10.00 for the set
i like the way it look but if need be i'll switch to pcv system
Old Sep 6, 2011 | 11:17 AM
DrainBramage's Avatar
DrainBramage
Mike, engine looks GREAT! I wish mine was that clean
What cam and carb did you pick to go with that intake?
Old Sep 6, 2011 | 08:33 PM
MIKES 68 F100
LUNATI VODOO CAM AND A HOLLEY AVENGER 670 AND HEADERS !
headers were a bitch to install . no go for starting her up today lots of little things left to do so the plan is get little things done during week after work and saturday morning scare the neighbors ..FUN FUN!!!
Old Sep 7, 2011 | 01:47 PM
MIKES 68 F100
pic of in truck some acessories installed
Old Sep 12, 2011 | 01:06 PM
MIKES 68 F100
FYI
GOT HER RUNNING, check out thread and video , thanks everyone for your help !
here
https://www.ford-trucks.com/forums/1...-is-alive.html
teched
Apr 1, 2016 12:06 PM
DutchB100
May 17, 2011 11:56 AM
boxer.fan
Jul 15, 2009 10:50 AM
thunderguns71
Apr 16, 2004 02:17 AM
jbearford
Jan 22, 2003 11:46 AM
