Checking trans fluid level? WTH.
Old Sep 3, 2011 | 06:40 PM
Devilmanak's Avatar
Devilmanak
I am a mechanical person, so I feel like an idiot asking this, but what the heck is going on with the dipstick on my 2000 Ex? I just put a FTVB in, I swear I got 2 gallons of fluid out of the drain plug, when I should have gotten 5 quarts. I have a feeling the previous owner overfilled it badly. I can't for the life of me figure out my dipstick. I get fluid on TOP of the dipstick when checking it, but none on the BOTTOM. SO I don't know if it is picking up residual oil from the tube on top when I pull it out, or if something is scraping the fluid off the bottom of the flat of the dipstick when I pull it out? It has taken 7 quarts so far and shifts fine, but I don't want to keep driving it if it is low. Anybody else have this going on?
Old Sep 3, 2011 | 06:48 PM
Milwaukee1979F150's Avatar
Milwaukee1979F150
My suggested why not ever FLUSH whole oil.
Torque convertor had drain plug.
Let that Excursion sit overnight then start and put in Neutral then look how level fluid is.
Old Sep 3, 2011 | 07:13 PM
Devilmanak's Avatar
Devilmanak
Thanks for the input, but you didn't address my question. I didn't drain the whole thing because the whole thing is coming out next week.
Old Sep 3, 2011 | 08:23 PM
EXv10's Avatar
EXv10
The tranny is low on oil when you checked it. The oil on top of the stick is merely scraped off the sides of the tube. Keep filling until oil shows on the bottom but when you check it; dry the stick, put the stick in and pause about 6 inches above bottoming out (to align the flimsy blade), then quickly plunge the stick to the bottom and quickly back out.
Old Sep 3, 2011 | 08:42 PM
Devilmanak's Avatar
Devilmanak
THANK YOU!!!
That is what I needed to know, I figured it must be low but didn't want to overfill, and wasn't comfortable driving it until I knew for sure. Figured there must be a trick to it, lol.
Thanks again!
Chris
Old Sep 4, 2011 | 05:43 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Why put it in neutral? Check it in park.
Old Sep 4, 2011 | 09:42 AM
Milwaukee1979F150
My teacher say only check fluid in Neutral so I been doing that way.
Old Sep 4, 2011 | 10:33 AM
Mark Kovalsky
Your teacher is wrong. Tell him I said so. On Dodges that may be necessary because their transmissions do something weird in park, but not Ford.
79BRNC
Sep 17, 2008 12:04 PM
cmoffatt23
Mar 8, 2008 06:53 PM
PowerstrokeJunkie
Aug 23, 2005 10:09 PM
dryul
Aerostar
Jul 8, 2004 09:45 PM
desertstorm-007
Aerostar
Sep 22, 2003 01:55 AM
