Door windows
Old Sep 3, 2011 | 10:00 PM
NtShade's Avatar
NtShade
Door windows
Okay a friend came out today with his dad and they got the window regulators out of the doors. We have not gotten the door latches out yet. In the process one of the vent window frames were broken. My question is will the window regulators work if I leave the vents out and just put bigger windows?
Old Sep 3, 2011 | 10:59 PM
underthebridgejim's Avatar
underthebridgejim
FTE fan
They make a kit to convert to one piece glass wich is available most catalogs, but if you take out the vent frames and devider there wont be a track for the glass to run in. I know Classic Haulers carry the kit(1877 252-1956)
Old Sep 3, 2011 | 11:41 PM
ALBUQ F-1's Avatar
ALBUQ F-1
What year of truck do you have?
Why not just buy a new window frame?
Old Sep 3, 2011 | 11:57 PM
arrowheadfred's Avatar
arrowheadfred
Like jim said they make a kit. You can use your regulators but ya have to get the kit or do away with the regulators and put power windows in it. If ya put solid glass like i did you also have to cut the tabs out that the devider mounts too. Its in the instuctions that comes with the kits. NEEDS TO BE DONE BEFORE ANY PAINTING IS DONE. GOOD LUCK !!!!! Its easyer and cost less to put big glass in then to rebuild the vent windows.Just depends on what look you want . Good vent window are getting hard to come across. ILYA may have some !!!!
Old Sep 4, 2011 | 02:48 AM
51PanelMan's Avatar
51PanelMan
Thanks for the plug, Dale. Yes, I have a pair that I'll be pulling from a 51 Deluxe cab doors. The chrome is peeling and rusty, but the frames look solid. They'll fit 48-52 trucks. PM or email if interested.
Old Sep 4, 2011 | 09:56 AM
NtShade's Avatar
NtShade
Mine is a 1948 F2
Old Sep 4, 2011 | 10:13 AM
Moe Craig's Avatar
Moe Craig
What part of the wing broke and which window?
Old Sep 4, 2011 | 10:23 AM
NtShade's Avatar
NtShade
Pasenger side the part that pivots at the bottom it broke off at the vent frame bottom.
Old Sep 4, 2011 | 10:35 AM
NtShade's Avatar
NtShade
Would JBWELD work?
Old Sep 4, 2011 | 10:45 AM
ALBUQ F-1's Avatar
ALBUQ F-1
The part shown below? It rivets to the frame, can be re-riveted if not rusted too bad (or welded). Forget JB Weld.
Old Sep 4, 2011 | 10:54 AM
Moe Craig's Avatar
Moe Craig
How soon do you need one? This winter I hope to be putting my new set in my '49 f1... My passenger is all there, let me take a look at it and see if it's good or not... is the rest of your frame still good? My drivers side is broken at the bottom pivot point... and the top pivot was broken off so I was missing the window frame... I silicone a piece of Plexiglas in to the opening... If you use silicone to hold the frame in place temporarily until you get a replacement it will do less damage when you try to change it out...
Old Sep 4, 2011 | 11:17 AM
NtShade's Avatar
NtShade
I am in big hurry. I still have so much to do to keep me really busy.
Old Sep 4, 2011 | 11:18 AM
NtShade's Avatar
NtShade
Make that NO big hurry. I have to find all the parts for this wonderful old truck. And get the tailgate remade and probably get a tetnus shot.
Old Sep 4, 2011 | 12:15 PM
Moe Craig's Avatar
Moe Craig
I the frame that holds the glass on mine is rusted on the inside of the cab... You may be able to find just the pivot point and replace it...
Old Sep 4, 2011 | 12:21 PM
NtShade's Avatar
NtShade
Okay I will check all my catalogues.
