should the engine be warm before an oil change??
09-03-2011, 01:17 PM
About to change my oil... Just has been sitting overnight and the engine is cold. Should I drive it around first or is a cold change alright?
09-03-2011, 01:21 PM
on
itll help it drain out if its warm
09-03-2011, 01:36 PM
on
If you're using 15w40 and on cold oil, it will take forever to drain. I'd warm it up too.
09-03-2011, 01:52 PM
The engine should be warm. The oil flows faster and helps get keep everything in suspension.
09-03-2011, 03:45 PM
Yes, it should be warm. But if its hot, you will get oil on your hand and regret it. Its not painful, but very uncomfortable. Ask me how I know.
09-03-2011, 03:47 PM
I always change the oil as soon I get home after a drive.
09-03-2011, 05:25 PM
on
Quote:
Originally Posted by
TreySpooner65
Been there too many times, it's times like that that push me toward a Fumoto.
09-03-2011, 05:28 PM
Hot is better. I have a pair of pvc coated cloth gloves that are excellent for hot oil changes. You can do it when the things up to temp and not burn yourself.
09-03-2011, 05:40 PM
jt371
TreySpooner65
Yuppers! 15-20 minute drive and drain!
09-03-2011, 06:52 PM
I got me a fumoto valve to solve the hot oil issue
lonestarpaul2003
01-16-2012 08:23 AM
GeneLaw1
01-10-2012 05:38 PM
jetch114
02-07-2007 03:53 PM
swanee
05-22-2006 07:36 AM
TallPaul
Oil & Lubrication
32
10-28-2002 04:44 AM
