Cold Weather Oil
Old Jan 14, 2012 | 09:36 AM
lonestarpaul2003's Avatar
lonestarpaul2003
Cold Weather Oil
I just moved from Texas to the Denver area and need to change my oil. What is the best oil for cold temps?
Old Jan 14, 2012 | 10:03 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Welcome to FTE.
How about a little more info. What engine, year, things like that.
Old Jan 14, 2012 | 10:49 AM
BareBones's Avatar
BareBones
Assuming you have a gas engine, I would definitely go with a synthetic oil during winter. They flow much more freely than dino, which helps with cold starts.
Old Jan 14, 2012 | 10:55 AM
galaxie641's Avatar
galaxie641
If it is the 6.0L in your profile 5W40 would be best. They get a little bitchy with 15w40 under 20*F.
Old Jan 14, 2012 | 11:18 AM
lonestarpaul2003
Sorry, am new here today. I assumed when I filled out the profile, the info about the truck would appear in the post. Guess not.
Yes Galaxy, it is the truck in my profile.
Thanks for the reply and he advice.
Old Jan 14, 2012 | 05:45 PM
tonefordays's Avatar
tonefordays
Popular choice (as mentioned earlier) 5-40 synthetic. Lots of guys like to run Rotella T-6. It's easier on the injectors during cold starts. On a side note, using a fuel additive like Diesel Kleen (white bottle) keeps the fuel for gelling in cold temp, also good for your injector.
Old Jan 14, 2012 | 05:56 PM
Ian123's Avatar
Ian123
I use 10w30 semi synthetic because its a lot cheaper than full synthetic 5w40. It definitely sounds better when I first fire it up in the morning (compared to 15w40) and I think it idles quieter too, but that might just be in my head.
Old Jan 14, 2012 | 06:13 PM
lonestarpaul2003
Ended up buying 5-40 synthetic (Rotella T-6) Have a lighter wallet tonite. Thanks again for the input gents.
Old Jan 14, 2012 | 06:33 PM
tonefordays
Yeah, stuffs not cheap. Cheapest I've found it, is at Wally World for $22/gal as compared to almost $28/gal at Autozone. I'll usually buy a gallon here and there over the course of a few weeks prior to changing my oil, that way I don't get hit with sticker shock.
One other thing, it's important to use OEM oil filters. Lots of threads here regarding the topic, just thought I'd give you a heads up.
Here's a good place to buy filters at a reasonable price.
Ford 6.0 Liter Turbo Diesel Truck Filters, Air Filters, Oil Filters, Transmission Filters And Glow Plugs - Diesel Filters,Additives,brake rotors, and brake pads for Chevy, Dodge and Ford Diesel Trucks
Old Jan 14, 2012 | 11:53 PM
powerstroke72's Avatar
powerstroke72
Moved to the 6.0L Power Stroke Diesel forum.
Old Jan 15, 2012 | 12:33 AM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Also, watch your fuel up there. Use Diesel Kleen in the white bottle this time of year, it has anti-gel in it. Plugging your truck in will also make it happy!
Old Jan 15, 2012 | 01:55 AM
Roasted7's Avatar
Roasted7
I'm finding out that my truck only likes Mobil 1 turbo diesel oil and NOTHING else. I live in West Yellowstone Montana, the coldist place in the country. -25 last night.
Old Jan 15, 2012 | 06:45 AM
06F350PSDDually's Avatar
06F350PSDDually
I went to the local dealership this past Friday to get some oil and filters (oil and fuel). Told the guy I wanted Motorcraft 10w/40 (or was it 15w/40 - whatever the manual said). He goes to the computer and comes back saying the computer recommends 10w/30 for this time of year. I was flabbergasted. I live in Virginia and our winters are not bad, this winter is especially mild (so far). I don't think we have had any days/nights below +20 degrees F. Has anyone else experienced this recommendation? Do I need to avoid this parts person? I stuck with the 10 or 15w/40.
Old Jan 15, 2012 | 07:08 AM
bismic's Avatar
bismic
Ford recommends the following (updated after the manual was published):
Below 20*F use a 5W40 or a 10W30. The 15W40 (and of course the 5W40) should be OK above 20*F
Above 50*F use a 5W40 or a 15W40.
The 5W40 is a GREAT all-around oil. Ford didn't recommend it at first because they did not have one that they sold.
Ford Truck Enthusiasts Forums - bismic's Album: Miscellaneous - Picture
Old Jan 15, 2012 | 08:59 AM
roadrunner01's Avatar
roadrunner01
All of the local dealerships around me have been recommending 10w-30 for the last three years or so. It is a much cheaper alternitive to 5w-40, the cold flow viscosity between the two are almost identical. I'm in NW OH and have been using 10w-30 all year around for the last 55,000 mi. or so with zero issues.
My guess is that Ford must have sent the northern dealers a TSB regarding hard cold starts and started recommending 10w-30, although it was already in the owners manual everyone has the mindset "if its a diesel it needs 40wt." Prior to 15w-40 becoming the "norm" 15 or so years ago all we ever ran in all of our diesel engines was straight 30wt.
All of the viscosities mentioned "will work" in your region, with the 10w-30/5w-40 providing easier cold starts, and they will be much easier on your injectors.
