C4 problem
Old Sep 3, 2011 | 01:17 PM
jrlec1020's Avatar
jrlec1020
C4 problem
I have a mid 70's C4 trans in my 72 F100. When the trans is cold (first start of the day) I'll put it in gear and start to pull out of my driveway. The trans will slip and it won't go until I rev it two or three times. It will do this for approximately 2-5 mins after the first start of the day or if it has been sitting all day. It's not slipping out of gear. It almost feels like when your clutch is going out on a straight drive trans. After 2-5 minutes it will run good all day as long as it doesn't sit a long time to let the trans cool down all the way.
I've adjusted the linkage both ways. The fluid is clean and at a good level. I haven't checked the vacuum modulator. Could that be going bad? Maybe the filter screen is dirty? Maybe I'm not adjusting the linkage enough?
Any ideas?
Old Sep 3, 2011 | 03:24 PM
jk080's Avatar
jk080
Transmission Rebuilder
Sounds like to me that the rubber seals inside the trans have hardened and cant seal until the fluid heats up. The C6 trans will do this too.
Old Sep 3, 2011 | 07:05 PM
jrlec1020's Avatar
jrlec1020
I'm not seeing any leaks from the transmission. If the seals were hardened wouldn't I see leaks?
Old Sep 3, 2011 | 10:34 PM
jk080's Avatar
jk080
The seals I am talking about are all internal, you wont see any leaks.
Talyn
Sep 30, 2012 11:15 AM
jrlec1020
Sep 3, 2011 11:05 PM
bomberboat
Oct 27, 2008 01:45 PM
WorkVan58
Aug 4, 2008 07:28 AM
danimal
Feb 7, 2006 11:33 AM
