not my trans problem
Old Sep 29, 2012 | 07:16 AM
Talyn's Avatar
Talyn
I'm not 100% on whats going on here, but I'll say what was told to me.
its an auto.
Don't know what year.
Drives fine shifts fine till you stop, then wont re-engage into gear.
Says he has to shut it off and put it in park, start it back up, and when he puts it in drive, it goes again.
Sounds like a weird electrical issue.
I dont know anything about 4r100.
Old Sep 29, 2012 | 07:54 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
Does the RPMs go up when he pushes the pedal while stoped and in gear? Can he feel the trans slipping?
Will it move by putting it in 1st gear?
Old Sep 29, 2012 | 05:57 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I don't see how it could possibly be an electrical issue. When you put the shifter in D, the trans will engage without any electrical input. If it won't go with the shifter in D there is something mechanical wrong in the trans. I suspect a failing seal in the forward clutch.
Old Sep 29, 2012 | 09:44 PM
mec500's Avatar
mec500
fluid level checked first ?
Old Sep 30, 2012 | 11:15 AM
Talyn's Avatar
Talyn
Sorry bout the thread guys. I called him after I posted this and he had taken it to a trans shop.
Apparently he burned out a set of clutches.
now the Trans mechanic is saying something about stuffing 9 clutches in there or something so he was asking me about that.
I'm sure you could stuff an extra 1 or 2 in there.
I told him he needs to get some valve bodies and stuff like that to make them shifts snappier for hauling his huge *** trailer.
290k on trans though, not bad I guess.
captain1997
Nov 28, 2013 09:37 AM
jrlec1020
Sep 3, 2011 10:34 PM
rb8612
27
Apr 10, 2011 08:10 PM
randomhero1172
19
Dec 23, 2008 04:46 PM
mchild
May 28, 2002 12:26 PM
