Call them in the AM, they can probably change it for you. Regarding usps priority mail- I parted out a car and shipped dozens of parts all over the country using priority mail. Nearly everyone received their parts in two days.
Well, I sent an email requesting change. We will see I guess.
Thanks Clay. That truck of mine is setting in the garage waiting on those rings. I need to pull the tractor to the farm to Bush hog a place for those Whitetails. So, alot depending on a little O ring.
The answer for anyone needing to get o-rings NOW in the case of an emergency fix, the size is #202. You could technically use plain old rubber ones for a temporary fix (a week or two), but definitely get VITON or better ones for a more permanent fix.
The first time I needed these rings, back in November, 2004, I used two Danco #90's from Home Depot from their plumbing department. They were for water use, and made of BUNA, not BUNA-N (nitrile), and should have expired very quickly. In the meantime, I got some Viton rings and carried them around. When they first became available, i got some of the blue ones from Guzzle.
Thanks again, Bob!
I carried those fluorosilicone ones around in my center console until March, 2009, when I developed another leak in those water-grade rings.
I don't plan on ever having to replace these blue ones again.
