service engine soon light on
Old Sep 8, 2011 | 09:06 PM
Bpayton's Avatar
Bpayton
I just put on new 4" exhaust today went to start it and the battery was dead. I finally get the battery charged up enough to start and now the service engine soon light is on. I don't know if its from the thing having to really change the dead batterys or the new exhaust. What do u think?
Old Sep 8, 2011 | 09:22 PM
nookiemonster55's Avatar
nookiemonster55
check your map sensor connection.... make sure its snapped on real good first thing i would look at without using a scanner.....curious as to what all you tore down to put it on....like i said... need a scanner to be more specific and check all connections again....take it it runs well? also give us a year make model and tunes if ya gottem...
Old Sep 8, 2011 | 09:57 PM
Bpayton's Avatar
Bpayton
Ya it runs fine. I took it out on the e way seems good. It's an 01 excursion no tuner yet. Only thing I have changed is the intake and exhaust. Not really sure where the map sensor is.
Old Sep 8, 2011 | 10:04 PM
snakedoc's Avatar
snakedoc
it is near the fire wall on the PS above the AC lines going to the cab.
Old Sep 8, 2011 | 10:21 PM
nookiemonster55
assuming you unhooked that sensor its bolted on to the evaporator thingy as stated doublecheck connections charge battery.......and a scaner will be your best-est friend in the future.....
Old Sep 9, 2011 | 06:28 AM
Bpayton's Avatar
Bpayton
I think I found the map sensor and it looks like it is plugged in correctly. I was messing around the down tube on the turbo so not sure if there is anything else over there that I could have messed with. I looked pretty good last night and didn’t see anything obvious.
I’m going to scan it here at work today. I will post what I find.
Old Sep 9, 2011 | 07:55 AM
Bpayton's Avatar
Bpayton
Ok it was a 1690 code "waste gate control solenoid". He cleared it out and did a diagnostic on the truck and it went thru everything and it passed. So for now everything seems ok. I’ll drive it around and make sure it doesn’t come back. maybe I knocked it when I was putting the down tube on or something.
TayzGpa
6.7L Power Stroke Diesel
Oct 5, 2017 07:50 PM
ExcursionSVOand5.0
Modular V10 (6.8l)
18
Jan 27, 2010 07:36 PM
sjcolu
Apr 9, 2007 09:25 PM
SimpAmz
Dec 30, 2001 10:47 PM
