Fuel Pooling on Engine Block
Old Oct 6, 2017 | 03:49 PM
Kainoa21's Avatar
Kainoa21
Aloha! New to this forum so please forgive my ignorance. I have a 96 7.3 with 159k original miles. I notice recently that fuel mix with oil was leaking in my drive way. The other day, I took it to get service and when it was done. I notice that the truck was not idling right. It was acting like it was going to stall or die out. The RPM was between 800-1k. Just need help trying to figure this out,. I started it today and it was fine for a minute then it went back to the sputtering and the check engine light came on. Any help or direction would be much appreciated.
Old Oct 6, 2017 | 08:36 PM
oldbird1965's Avatar
oldbird1965
Welcome and I've been on here for 13 years and I'm still ignorant. lol If your losing a lot of fuel then that might be your problem-losing fuel pressure. There is two little hoses behind the fuel bowl that leak, might be that!
Old Oct 6, 2017 | 09:10 PM
mcali2's Avatar
mcali2
Or the steel fuel line may be rusted or the fuel bowl rusted. Salt water and all.
Old Oct 7, 2017 | 11:27 AM
BBslider001's Avatar
BBslider001
In other words, get under the hood with a flashlight and check the ENTIRE fuel system. There are a 100 places that fuel can leak and pool in the valley....o-rings, hoses, fuel pump, fuel bowl, fuel lines. Only you can tell by looking at it while the truck is idling.
Old Oct 9, 2017 | 08:59 AM
knottyrope's Avatar
knottyrope
grad a inspection mirror to see under the bowl and fuel pump
My pump was leaking and the line between bowl and pump was swelling and leaking bad.
Brown Falcon
21
Apr 21, 2012 10:58 PM
donnyglaze
Feb 14, 2011 12:36 PM
clbostian
Oct 10, 2010 11:09 AM
SomeReallyOldGuy
Jun 25, 2008 10:56 PM
custom_nirvana
Jan 30, 2008 01:16 PM
