No heater blower...good starting point for fix?
Hey guys...I've been fixing everything else on this thing thought my next project needs to be some heat for Winter.
Fan used to work but made a funny noise on any setting higher than one. Then one day it just did not work at all.
All fuses look good and I checked the ground wire on firewall.
What would be a good starting point to fix it?
Relay, resistor or just motor itself?
Thanks!\
73 F100 360 AT 2WD (no AC)
(just hooked it directly to battery for a second and the motor worked)
Thanks!\
Check and make sure the terminals on the switch and resistor are clean and free of corrosion.
Generally, the reason the resistor goes bad is one of the little coils breaks and this can be checked visually. But usually when the resistor goes bad you still have high speed.
See if you have voltage going to the resistor. If you don't have voltage, check to see if you have voltage at the switch.
I just took care of this on my truck - under the dash where the heater box connects to the defrost duct had about a 1" gap where they meet and all the air was just blowing up under the dash. I fixed the alignment and used duct tape to go all around the connection and seal it. I'm getting much better air at the defrost but it still seems fairly week (but I might just be used to new vehicles).
Shiner
01-15-2006 02:48 PM
wolfen
1983 - 2012 Ranger & B-Series
15
10-06-2003 06:34 PM
