460 valve adjustment question
Old Aug 31, 2011 | 08:22 PM
riverratba's Avatar
riverratba
i have a 1996 F350, 460 fuel injected. i have a valve making some tapping noise, ive tried some oil additives to see if the lifter will free up but no luck. i'm going to put a new set of lifters in it. does these valves have an adjustment or just torque down. any other tips on doing this job will be greatlt appreciated.
Old Sep 1, 2011 | 04:03 PM
littlehusky's Avatar
littlehusky
should be a bolt on arm. would be good to check, never know what previous owners can do.....
Old Nov 10, 2011 | 11:12 AM
4x41977's Avatar
4x41977
there just torqued down. Read repair manual and check torque specs. You dont have to have stress off the valves or anything. Just toruqe to spec.
Old Nov 10, 2011 | 03:31 PM
mark a.'s Avatar
mark a.
I would check their preload when you put the new ones in. I would also put some new valve stem seals on and check the guides out for wear while you have the springs off.
Irv
Oct 23, 2006 09:27 PM
michaelbrainardatwor
May 10, 2005 02:03 PM
freezeplug
Jun 23, 2003 11:41 AM
GEAH
Apr 15, 2003 06:49 AM
bigsnag
Jul 2, 2001 07:52 PM
