drivetrain CLUNK...
Old Jul 15, 2013 | 07:37 AM
  #46
FordService's Avatar
FordService
Official Ford Rep
Originally Posted by bigdaddyII
My 2012 with the single drive shaft had this clunk/ bump, when taking off from a stop. It just occured within the last 5-6k miles. My 2005 that was traded on my wife's Fusion had this same issue, it had the 2 piece drive shaft. I always thought it was a characteristic of the truck until the new one started doing it, and I know it didn't do it before. I will mention it to the dealer at its next oil change, it has 24,000 on it now...
Hi bigdaddyII,
I'm happy to get this in front of your regional customer service manager (CSM); they'll smooth the way for you when you head into the dealership. If you'd like me to assist, send me your VIN, dealer, mileage, daytime phone number, and full name; I'll make sure your CSM is alerted.
Thanks!
Crystal
Old Jul 15, 2013 | 06:06 PM
  #47
blueovelboy's Avatar
blueovelboy
Originally Posted by D8chumley
I'm not going to lie I would like to see that also It would liven up the ol' forum haha!
Old Jul 23, 2013 | 10:16 AM
  #48
ksmustng's Avatar
ksmustng
Traded in my 2011 that had the clunk. My 2013 does it too. It almost has 200 miles. I thought this was something only Chevy's did??
Old Jul 24, 2013 | 11:16 AM
  #49
bigdaddyII's Avatar
bigdaddyII
Just got back from the dealership. They greased the slip yoke (my mistake in my earlier post, I do have the 2 piece drive shaft). When it starts clunking again they will do it again all the way to 100,000 miles. Then I probably won't worry about it.
Old Jul 24, 2013 | 06:51 PM
  #50
blueovelboy
it sucks ford did think of redesigning the drive shafts but that's not going to make them money so why do it.
Old Jul 24, 2013 | 09:02 PM
  #51
GuyGene's Avatar
GuyGene
Originally Posted by kgoeke
I have a 2010 Screw 4x4... Supposedly the 2011 and new units have a clutch installed to help alleviate this noise, but that may just be an answer to get you to trade in on a new vehicle with the same issue.
Whew, where do I start with the logic of that last sentence - not from you, kg, but that there seems to be so many brand loyal buyers that Ford thinks like this! That statement is sad, but true for too many people. "My '12 has ___ problem, so I'm trading in for a new truck"!!?!?!?!!! For the same make!! Me? NO WAY!! Usually if there are known troubles with a brand of anything, hey, I'm gone. Consistent stuff I mean, not normal problems that can come up. Example, GM 5.3 engine oil usage issues, etc. I wouldn't trade a fairly new truck on the same make that is giving me trouble!
Who was it that defined insanity as doing the same thing over expecting different results? Ford needs to fix all this clunking mess. Soon.
Old Sep 12, 2021 | 10:37 PM
  #52
jrap09's Avatar
jrap09
2012 Ford Expedition tail shaft clunk
Originally Posted by Aggie-150
My '10 XLT 4x4 has the clunk too. I have a one piece driveshaft, but everyone else seems to have the two piece? The dealer still did the TSB for greasing the slip yoke and it drove butter smooth for about 600 miles and now the clunk is coming back.
What exactly is the problem? Are the male/female connections too loose causing the play? Can buying a better slip yoke that fits better stop the clunk? I read somewhere on a Ford forum that a guy took a thick rubber hose and basically jammed it between the threads of the male and female components and it stopped his clunk. I plan on keeping this truck to over 200,000 miles and I'm afraid that wont happen unless there's a permenant solution for the clunk. Our 01 Expedition has over 140k on the clock and runs perfect
on my 2012 Ford Expedition I got that clunk every time it shifts gear when I'm riding slow walking forward to reverse I got under there and I noticed a lot of Slack and a clunk at the tell shaft of the transmission is there any easy fix
Old Sep 16, 2021 | 07:25 AM
  #53
BassFantasizer's Avatar
BassFantasizer
That's a well known issue that Ford has had for many years. My '97, with a 1-piece drive shaft had it too. Ford had a special grease for lubing the slip yoke (or recommended one). But it was a temporary fix as the grease would squeeze out of the joint with every change in load. I was always concerned that not lubing it would cause excessive wear but in 300,000 miles it never gave me a problem. Just an irritation.
sgeorge
Dec 27, 2016 09:10 PM
FoMoFun
2009 - 2014 F150
Mar 9, 2011 12:12 AM
aghaferi
2004 - 2008 F150
15
Nov 1, 2006 09:28 AM
pocobueno
May 26, 2004 09:15 PM
Michael60
Jun 5, 2003 07:42 PM
