1978 - 1996 Big Bronco
motor swap question
Old Aug 31, 2011 | 03:08 PM
joe f350's Avatar
joe f350
Originally Posted by jas88
I would say that holes in the piston walls of the diesel from cavitation are more common than blown-out spark plugs in a Triton.
https://www.ford-trucks.com/forums/8...s-in-here.html
it only becomes a problem if u dont use the right coolant
Old Aug 31, 2011 | 03:19 PM
Dodge/Cummins's Avatar
Dodge/Cummins
Originally Posted by joe f350
yea the motor has to be newer them the said vechial and a 7.3 no way
get a junk 7.3 and put enough of it's parts (like valve covers and serpentine accessory drive) on a 6.9L so it looks like the 7.3.
Old Aug 31, 2011 | 03:27 PM
joe f350's Avatar
joe f350
yea i know i could do that but a v10 would be great im all ready geting ten mpg y not do it in style
Old Aug 31, 2011 | 04:49 PM
Dodge/Cummins
I have a '95 Dodge V-10 for you............................ 8.0L, 488 Cubes.
Old Aug 31, 2011 | 07:35 PM
greystreak92's Avatar
greystreak92
If we are throwing out non-Ford options, I can get my hands on a Cadi 472 (7.7L) or 500 (8.2L) if you want an indestructible V8 with high enough nickel content in the heads and block to run unleaded without burning valve seats. Minor porting in a 472 with some carb tweaks will get you into the upper 300 HP range.
Old Sep 1, 2011 | 08:46 AM
jas88's Avatar
jas88
And the electrolysis/cavitation was only in the 7.3 IDI and PowerStroke, more so in the IDI.
And your point is what? The IDI is what you were talking about. All I am saying is that the diesel is not without it's own set of fleas.
IMO the biggest impediment to putting a diesel in a Bronco is the extra 600 pounds you are putting on the front of a vehicle with a very short wheelbase.
I like everything Ford, even the IH stuff, but the Triton V8s are wonderful motors that make a bunch of power given their displacement.
Old Sep 1, 2011 | 02:53 PM
Dodge/Cummins
My point is that the cavitation problem can be solved by SIMPLY putting the right cooland in it and watching the pH levels.
The mod-motors problem is more complex and difficult to ATEMPT to prevent.
You're right about the extra weight and that is definitely a factor to take into account.
Old Sep 2, 2011 | 01:57 PM
kenpobuck's Avatar
kenpobuck
When done right the wieght is no problem lol. Just swap it all out like I did to mine. My Bronco handles better with the 1 ton stuff under it then it ever did as a 1/2 ton with the sway bars. Besides, my fuel mileage is a lot better than it ever was as a gasser.
mattmattf14
Nov 18, 2016 10:31 PM
rowekmr
Nov 9, 2010 08:59 AM
bronco0473
1966 - 1977 Early Broncos
Sep 15, 2008 01:00 PM
Keith1984
Modular V8 (4.6L, 5.4L)
Nov 5, 2004 04:02 PM
bchitwood73
1983 - 2012 Ranger & B-Series
Jul 8, 2004 11:47 AM
