2.9 V6 Swap problems
Old Jul 8, 2004 | 09:01 AM
bchitwood73's Avatar
bchitwood73
Hello everyone,
Here is my problem, I have an 1989 Ford Ranger 4x4 that came stock with a 5 speed and also the 2.9L V6. The motor went bad on me so I pulled it and got another motor that came out of an 88 Bronco II with an Automatic trans. My problem is that the wiring harness from the Bronco II motor does not seem to have the same connections as my Ranger does. The motor only has 2 main plugs that go to the fuel injectors and sensors, and the truck that I am dropping this into has 3 main plugs.
The only thing I can think of is that I am missing some type of harness that goes from the extra truck side round shape plug and then into the flat shape plug for the motor distributor? I am thinking this is the case because I can't seem to find the plug that would fit the distributor on this new motor but my old motor had the same type, and shaped plug for the distributor. Does anyone out there know what this extra plug is for. I have two gray colored plugs, and one black plug on the truck side, and one black and one gray on the motor side. The black plugs fit into eachother, but so do the gray ones.
Thanks,
Brad
Old Jul 8, 2004 | 11:47 AM
thecannibal's Avatar
thecannibal
Whatever doesnt match try to salvage from the engine you just pulled. One note is when your swapping the engines, you need to swap the computers too. Just because the engine is the same doesn't mean the computer is the same.
TurboVern
Jan 7, 2018 09:27 PM
89F150_5.8L
Jul 25, 2011 10:32 AM
andy96xlt
Dec 11, 2010 09:02 AM
Little old Bronco
Bronco II
26
Dec 1, 2003 07:03 PM
gdcook81
Bronco II
Mar 27, 2003 09:27 PM
