ABS light is on and Tow Haul flashing and speedometers not working...
I have read numerous threads and unfortunately not able to fix this. What I've done is replaced the speed sensor located on the rear differential. Also replaced both ABS front sensors and VSS sensor located on top of transmission. All sensors are oem. In addition also traced all wires for continuity and appear to be in excellent condition. CODE...speed sensor A fault. Any input on this would be greatly appreciated. Thanks.
Try forscan. It is available free at www.forscan.org. You'll need an ELM327 adapter that is under $30. I bought mine on Amazon. This will read all the codes in all of the modules on your truck.
Just a thought...
Metal debris in the rear diff can cause false faulty ABS sensor problems. Solution is to remove the diff cover, clear and refill with new oil.
Sensor cracks can happen with replacement and faulty cable connections to the rear diff sensor can also cause ABS rear diff sensor failures.
1999XLT
1997-2006 Expedition & Navigator
10-12-2003 01:59 AM
