Sponsored by: Real Truck
ABS light on
Old Aug 23, 2016 | 09:12 AM
Jerkys1212's Avatar
Jerkys1212
ABS light on
I know it has been discussed on here a bit, but nothing helped for my issue. I went to have the code read, and it was no signal from the rear ABS speed sensor. I replaced the sensor, and the light is still on. Also my speedo is off a bit. It is reading about 7-10 miles an hour faster than what it should. The mechanic can't seem to find the issue. SO I am coming to the guys and gals that know more than them. I have a 06 F250, Powerstroke.
Jon
Old Aug 23, 2016 | 10:12 AM
camminich's Avatar
camminich
Did you have the codes re-read after fixing the rear sensor? I had the same problem on my F150, rear sensor code, replaced it, but the light stayed on. I re-read the ABS codes and then poof front right sensor was bad too. I had read that the ABS system doesn't compile all codes, once it has a fault it was stop on that error and produce the code. Once you resolve it, it cycles itself and could find a new code if you have more than one problem.
Also just as a second thought, when replacing my rear sensor a lot of people recommended checking the contacts on the wiring plug itself, I guess it is prone to wear too and can also cause an bad sensor code when it's just the plug or part of the wire.
Old Aug 23, 2016 | 12:22 PM
r2millers's Avatar
r2millers
I too have seen several posts where the two wires will rub, even with wire loom, and create an open. Mice, rodents, of many kinds like to chew too.
Bigb6.0
Nov 29, 2017 09:58 PM
Oilfan94
Jul 1, 2017 07:38 AM
wpwilburt791
2004 - 2008 F150
Sep 18, 2014 10:59 PM
Garrthomp823
Sep 8, 2014 07:58 PM
superv10
Dec 3, 2009 10:42 AM
