Battery not being charged!!!
Old Apr 3, 2003 | 06:22 PM
Snatch Block's Avatar
Snatch Block
Angry Battery not being charged!!!
The truck died on the Highway, Replaced the solonoid & alt. Tried the test when you start the truck then pull off the power lead to the battery. The truck still died. What can it be? It is an 89 F250 4X4.
Old Apr 3, 2003 | 07:19 PM
Franklin2's Avatar
Franklin2
Get a voltmeter and check the battery voltage with the truck off, and then with the truck running. If the voltage is higher with the truck running, then it is charging. The "pull the cable off test" must have come from the old days with points style ignition. That is a very risky test on a vehicle with electronic ignition and also dangerous to the EFI computer.
gabriell12123
Nov 4, 2016 05:38 AM
jazz77
15
Jan 11, 2016 01:05 PM
MDSuperDuty
Electrical Systems/Wiring
Dec 8, 2015 07:40 AM
jgossage
2004 - 2008 F150
Nov 28, 2015 10:42 AM
Stumpy350
Jan 14, 2006 11:51 AM
