i have 1978 f-150 4x4 as a daily driver. i do all my own work but my front axle housing is leaking from my driver side. i pulled out my axle to replace my u joints. i have looked every were an talked to all my local mechanics and they are stumped. can some please tell me were or if there is an outer seal is an were is a place to buy them
Your inner seals keep the oil in. I bet when your driving, the spinning of the axle is drawing the oil out to where it can drip. You have to take apart the diff to replace those two seals.
^^ What he said. Google "D44 inner axle seal replacement" or similar and you will find step by step info. You can click on the link for my 79 build and you can see what I did to replace them.
