6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
NOISE #3 LIFTER ?????
Old Oct 2, 2011 | 11:16 PM
  #31
Ian123's Avatar
Ian123
So was that $25,000 repair bill just for the new motor or does that include what they paid earlier for the fuel system repair as well?
Old Oct 3, 2011 | 06:17 AM
  #32
Bounds-Electric's Avatar
Bounds-Electric
FORD USER
That was for both repairs. They also replaced all push rods & rocker arms!
Old May 2, 2012 | 12:52 PM
  #33
zol_trix's Avatar
zol_trix
Hi guys
I had the same problem as you last week with one of my trucks. 207000KM. Lifter was stuck in place and the roller was missing, camshaft grinded. I lifted the cab, removed both heads send them to rebuild, put new camshaft, 16 lifters. Removed the oil pan for removing metal from the roller lifter. The block was not worn at all, the driver noticed the irregular noise under the hood before it was too late. Also replaced all rocker arms assembly because they were worn-out. I replaced high pressure pump, egr coolers and waterpump beacause I do not wanted to do this next month.
Old May 2, 2012 | 06:08 PM
  #34
cheezit's Avatar
cheezit
did you replace the oil cooler? thats were the neddle bearings like to get traped.
Old May 2, 2012 | 07:04 PM
  #35
zol_trix's Avatar
zol_trix
No, I don't. I checked the oil pump gerotor and I noticed that nothing came throught it. The oil filter was fine too.
spquint
1983 - 2012 Ranger & B-Series
May 6, 2007 06:29 PM
javi2001
Dec 11, 2004 08:55 PM
dr-dirt
3.8 & 4.2L V6
Jul 16, 2004 12:57 PM
tank5879
1978 - 1996 Big Bronco
Feb 1, 2001 06:28 AM
