NOISE #3 LIFTER ?????
Aug 25, 2011 | 04:33 AM
FORD USER
037 - YouTube
2008, 6.4, 127,000 MILES Just had cab off replaced high pressure pump . I picked up now this noise, Any Help
Aug 25, 2011 | 04:53 AM
FORD USER
I also had new belts, tighters, pullys done while cab was off, checked all good, (run with belts off) noise is coming for inside valve cover around #3
Aug 25, 2011 | 05:36 AM
Well they shouldn't have messed with any of the valve train components to do the HPFP.
Does sound like something is dry in there.
Aug 25, 2011 | 09:27 AM
Quote:
Originally Posted by
Bounds-Electric
What are tighters?
Aug 25, 2011 | 05:01 PM
FORD USER
Rudiak
What are tighters?
Keeps belts tight,
Aug 25, 2011 | 07:44 PM
This noise could mean potentially big problems I'm afraid! Might have a scored cam from a bad lifter!
Aug 25, 2011 | 08:18 PM
I've been following this thread, that video sounds pretty ugly! What has the dealer said about this?
Aug 25, 2011 | 08:25 PM
How do you know it's a rocker and not a injector making the noise?
Aug 26, 2011 | 05:21 AM
FORD USER
ljutic ss
The tech electricly turned off injector with truck running with no change in noise, They changed rocker today no change in noise! Ford thinks its a failed lifter
Aug 26, 2011 | 05:28 AM
I would tend to think it is isolated at the lifter. Suppose they can do that with the cab still back on.
Wonder if they will or would want to pull the cab.
Aug 26, 2011 | 04:47 PM
FORD USER
Cab is coming off again. Tech thinks lifter failed messing up cam shaft.
Looks like a new lower half of motor.
Aug 26, 2011 | 05:31 PM
I suppose if they have to go in that far they would want it right out in the open. That is some rotten luck there.
Aug 26, 2011 | 07:11 PM
It is definitely strange that you only started hearing this noise IMMEDIATELY after the work was completed. Makes me wonder if they dropped a bolt or something while they were changing the HPFP???? That could cause serious damage.
Aug 26, 2011 | 07:15 PM
Almost sound like an injector hanging
Aug 31, 2011 | 08:23 PM
FORD USER
Noise was lifter! Metal in motor, crank scared, Motor comes out and will be replaced!
