gear shifter problem
Old Aug 24, 2011 | 08:13 PM
88dually's Avatar
88dually
88 c6, shift indicator reads d when in park, and 2 when in drive or reverse. How do i fix this ? And is it possible to get detailed instructions to fix it ? Thx guys
Old Aug 25, 2011 | 12:01 PM
Lazy K's Avatar
Lazy K
Look at the steering column between the steering wheel and the dash. Right at the dash you will see a two piece plastic cowl held together by two screws. Remove the screws and split the cowl apart.
You will now see the little inner cable that comes from the shift indicator hooked onto a spud on the shift tube. You will also see the outer cable with a plastic tab on it that is fastened to the dash with a single screw. Loosen that screw so that you can move the plastic tab back and forth. Move it to a position where the shift indicator points to where you want and tighten the screw. Check the shift indicator through the range of movement in the shifter, readjust the plastic tab if necessary. Refit the cowl.
Old Aug 25, 2011 | 12:27 PM
88dually's Avatar
88dually
That was perfect.
Thx for ur help
Old Aug 25, 2011 | 01:31 PM
tjc transport's Avatar
tjc transport
i ain't rite
well, i was close.
Old Aug 25, 2011 | 02:00 PM
88dually's Avatar
88dually
well Tom, you were close enuff. Thx guys, i appreciate the help
marvinlong
35
Aug 16, 2020 10:58 AM
JReagan90
Jun 13, 2013 11:32 PM
remix01
Feb 27, 2010 01:23 PM
bully 515
Sep 8, 2006 10:36 PM
