shift indicator
Old Sep 8, 2006 | 11:56 AM
bully 515's Avatar
bully 515
shift indicator
hey guys,
I have a 1998 4x4 eb 4.6, my problem is my shift indicator is out of wack! p is r and drive is 1. is this hard to adjust?? any help would be much appreciated.
thanks...
Old Sep 8, 2006 | 08:52 PM
twodazeoff's Avatar
twodazeoff
No, it is easy to adjust. Take the lower panel off that is under the steering collumn and look up on the passenger side of the steering column. There should be a small piece of white plastic with a black thumb wheel attached. There will be a small cable coming out of the top that is hooked to the shifter. Just turn that thumbwheel to adjust it. Try moving the shifter with the vehicle off through all gears.
Old Sep 8, 2006 | 10:36 PM
bully 515's Avatar
bully 515
Thumbs up
thanks! i fixed it.
