Shift Indicator Offset
Old Jun 13, 2013 | 08:00 PM
JReagan90's Avatar
JReagan90
Well, I'm not sure exactly what happened, but after backing out of a parking space and then shifting into drive, and noticed that the orange shift indicator was offset -- literally off to the right side where I couldn't see it. When I put it in park, it's over on the 1. I've got a '92 F-150 with an automatic. Anyone else had any experience dealing with this situation?
Old Jun 13, 2013 | 09:53 PM
1993_f350_2013's Avatar
1993_f350_2013
if you take off the panel below your steering collum you will see a cable with a loop on it that runs through a little fixture to adjust the shift cable it might have broke or came unscrewed.
Old Jun 13, 2013 | 10:43 PM
cjcocn's Avatar
cjcocn
Before you try that, look underneath the dash. There are some torx screws that are known to come loose. Once they do the shifter is way off.
Took me about 3 minutes to fix my shifter problem.
Old Jun 13, 2013 | 10:45 PM
cjcocn's Avatar
cjcocn
PS. A search of the forum should net you some pics. I am on my cell so searching is too onerous.
Old Jun 13, 2013 | 11:32 PM
Encho's Avatar
Encho
The Southernmost Mod
Does the lever feel just as tight and works as usual? then it's the little cable, does the lever feel loose but shifts alright? then it's the bolts, does the lever feel hard and some you have to make an effort to reach the gears at the extremes? adjust the shifter cable, if the problem persist then replace it ASAP or you'll break the shifter tube and things will get ugly and expensive.
tommyl
Dec 4, 2015 11:33 AM
WADED13
2004 - 2008 F150
Nov 28, 2011 07:28 PM
LSO1123
Oct 9, 2011 05:00 PM
88dually
Aug 25, 2011 02:00 PM
