ttb differential replacement?
Old Apr 3, 2003 | 11:55 AM
cryptonik420's Avatar
cryptonik420
Question ttb differential replacement?
Anyone have a link to instructions on how to perform this operation? I'm going to attempt to upgrade my gearset to a 4.10, but have not instructions for disassembling the TTB.
Old Apr 3, 2003 | 01:19 PM
MustangGT221's Avatar
MustangGT221
You have to take the axle out of the truck, and disassemble that way. Remove the driveshaft, tires, and unbolt the radius arms from the bracket off the frame. Unbolt the springs, steering...etc.
Old Apr 3, 2003 | 02:30 PM
tsheriff's Avatar
tsheriff
Why would you want to take the entire thing out???? If all you want to do is change the gears than you have to drop the center section out the back. Remove the wheels brakes and spindle hub on both sides till you can get to the axle assembies. On the driverside it just pulls out. But the pass has to be removed with the centersection. once you unbolt the centersection and driveshaft, you should be able to drag the 2 part shaft out with the diff or maybe rotate the housing to the point you can get the c clip. i see no reason to unbolt the springs and remove axle beams themselves. One thing check you may have the external retainer on the pass side shaft. i think its just a pin that goes through the yoke.
Old Apr 3, 2003 | 03:14 PM
cryptonik420
THANK YOU!
Old Apr 3, 2003 | 10:05 PM
steve83's Avatar
steve83
There are some pics in the 83 Bronco album in my sig link - I dropped my chunk to go back to 3.07.
mercracing84
Dec 15, 2010 06:57 AM
iron1951
Mar 16, 2010 09:08 PM
nobodyspecial
Offroad & 4x4
86
Jun 26, 2008 06:32 PM
1970Custom
Offroad & 4x4
18
Dec 31, 2005 05:02 PM
jimandmandy
May 22, 2002 01:09 AM
