C-6 behavior ?
Old Aug 23, 2011 | 04:46 PM
grinnergetter's Avatar
grinnergetter
C-6 behavior ?
I rebuilt my original trans from my 73 CS. Not because it needed it but I needed to swap tailshafts and housings to make it work in my 79 4x4 with 390. I was installing the transfer case and noticed I could not rotate the output shaft at all.
Took it apart and thought I had it (parking pawl in backwards). Reassembled and all is good until I torque the pump to specs. The shaft only turns counterclockwise when bolts are loosened.
I used a bit of grease to hold the spacers with tabs in place so I don't think one fell out and I triple checked.
Very confident that all discs are in correctly. I also used the parts from the same tranny, did not mix and match.
Has anyone had this happen and is it normal???
Old Aug 24, 2011 | 08:53 AM
grinnergetter
If I can turn it with pliers I'm going for it. Cab is off so I just want it to right BEFORE I put it on.
Rcmgiasson
Mar 29, 2017 08:14 PM
gingerbreadmaniac
Mar 12, 2011 04:22 PM
Jerry Gougeon
Nov 15, 2004 05:20 PM
sparky
Feb 4, 2001 12:18 AM
frankensteins4x4
19
Feb 1, 2001 03:35 PM
