C6 tailshaft lengths
Old Apr 10, 2006 | 01:26 PM
Rcmgiasson's Avatar
Rcmgiasson
i was wondering what tailshaft lenghts the C6 (small block bolt pattern)were all available in. My problem is that i took the transmission out my truck and took it to a place to have it rebuilt. The place who did it said the case was cracked so they rebuilt a different one. Now it would seem that my drive shaft is a bit short and i don't have the old case to compare it to. Any help would be greatly appreciated.
Old Apr 11, 2006 | 09:36 AM
stuart1's Avatar
stuart1
23" or 26 3/4"
Old Apr 29, 2006 | 06:12 PM
keeper's Avatar
keeper
I've been searching this entire network for info on short/long tailshafts to no avail. I can tell you this,I have 2 '78 4X4 PU's. One is reg cab the other is extended.The extended cab PU has about a 4 to 6 inch longer tail shaft that requires a longer adapter between the C6 tranny and my NP 205 X-Fer case. There is a difference. I have been trying to find out if I can change out the tail shafts. Does the shaft go all the way thrugh th tranny or is it splined somewhere near the back of th tranny.It's sad that a rebuilder that deals with this on a daily basis tryies to prey on the un-expected consumer that just wants the job done right the first time. Thanx for your time.
Old Apr 29, 2006 | 09:20 PM
mark a.'s Avatar
mark a.
All tail shafts will interchange. You have to take the whole trans apart to get at the snap ring that holds it in.
Old Apr 30, 2006 | 08:01 PM
keeper's Avatar
keeper
Thanks
mark a. A buddy of mine in our shop told me the same as you did. Can you or someone else direct me to a site where I can get a cut away view or step by step instructs on a C6 tranny
Old May 1, 2006 | 06:54 AM
stuart1's Avatar
stuart1
Follow the bouncing ball.
It's free.
http://www.transtarindustries.com/catalogs.asp
Old Mar 27, 2017 | 09:34 PM
scottzilla's Avatar
scottzilla
tail shaft lenght
Hello all. I have a 1972 f250 with a 360 or a 390. do you know what is the tail shaft length?
Old Mar 28, 2017 | 12:31 AM
stuart1's Avatar
stuart1
You have the truck.
Do you have a tape measure?
Old Mar 28, 2017 | 08:52 PM
scottzilla's Avatar
scottzilla
Yes i do have a tape measure. so what point to what point do i measure to the length? Thank you.
Old Mar 28, 2017 | 11:00 PM
85e150's Avatar
85e150
This, or any blow-up image of a C6, shows the separation of the main case and the tail shaft housing:
http://www.fordification.com/tech/images/c6_05.jpg
What are you trying to do?
Old Mar 29, 2017 | 08:14 PM
scottzilla's Avatar
scottzilla
i am going to buy a 800 hp rated transmission, and i am hoping not to have to change my drive line. thank you for your answer.
lotekinc
Oct 17, 2020 01:59 PM
madmacs
43
Jan 19, 2018 03:55 PM
svemike
53
Oct 19, 2016 12:42 PM
ualawhog
1997 - 2003 F150
May 12, 2016 08:38 PM
Blind Driver
Feb 29, 2016 11:43 AM
