Transmission sticking
Old Aug 22, 2011 | 04:57 PM
Sullid01's Avatar
Sullid01
Hi Guys,
Every now and then, the transmission sticks in 2nd or 3rd gear and does not shift when it is supposed to. Today was the worst by far - it was stuck in 3rd gear and rev'ed to over 3K with no shift. I got off the road and restarted it - no problem after that. It has been 23k since the last service and no towing in the interim. Trans fluid temp was 153 when it was happening. Any thoughts?
I was thinking about getting it flushed (maybe a little metal in the oil?)
Thanks!
Old Aug 22, 2011 | 05:21 PM
69cj's Avatar
69cj
Are you using OEM filters and Mercon SP or LV fluid? When you say 23,000 since last service, do you mean tranny flush? Every 30,000 miles per manual.
Old Aug 22, 2011 | 05:29 PM
Sullid01's Avatar
Sullid01
The last owner had a flush done at the dealership right before I bought it (at 25K mi). OEM filters and fluid done at Ford. I only have 48K mi on the truck right now.
Old Aug 22, 2011 | 06:30 PM
69cj's Avatar
69cj
Sounds like it could be a sticking solenoid but I'm not a tech. Possible a flush and new filters could help. A ford scanner would narrow it down. Sometimes paying the dealer diag. fees are the cheapest way to go. Throwing parts at a problem can get exp. and end up in more damage.
Old Oct 1, 2011 | 10:23 AM
Sullid01's Avatar
Sullid01
Just thought I would give some feedback. I got the flush done and it has not happened again. It has been a month or two, so there must have been some debris in there getting stuck every now and then. It was a bit before I was due for a flush - I also had them change both filters while they were in there. 69cj thanks for your help and advice - Dan
Old Oct 1, 2011 | 12:23 PM
69cj's Avatar
69cj
For future reference you only need to change the external filter. I do mine every 10,000 miles but I also tow a 31' 5th wheel. Internal filter stops trees and boulders and needs to be changed during rebuilds. Go to dieselfiltersonline.com and get the NTZ tranny filter. They make them for Motorcraft and are a lot cheaper. You can also get the oil and fuel filters there under the Racor brand.
Old Oct 1, 2011 | 12:58 PM
Sullid01's Avatar
Sullid01
Good to know - I did not want to take any chances since it was not really a routine flush. I get all my filters from Dieselfiltersonline - love them.
Old Oct 1, 2011 | 01:38 PM
Headviking's Avatar
Headviking
Just to be clear. Was it a hot/power flush or a complete drain and refill. My Friend has a 2001 with the same issue. He has about 150,000 miles on his. Since new he has only had I believe one hot/power flush all the rest have been drain and fills. A trans shop has suggested a drain and fill and not a complete hot/power flush. He claims that this may produce even more issues.
Old Oct 1, 2011 | 02:20 PM
Sullid01's Avatar
Sullid01
I had them do the hot flush, which I thought was the best way to get a complete fluid change. The drain and flush only removes about half of the fluid, right?
BTW, another possible reason for the transmission issues I was voltage related - I was having some battery issues causes by a loose connection on one of the terminals. It was fixed at about the same time, but the transmission problem seemed to start before that electrical problem developed. I only have 48K on mine.
Good news is the truck runs great again with no issues at all (for now )
Old Oct 1, 2011 | 02:51 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
The 2001 (7.3) transmission has a drain plug for the converter so it doesn't require a hot flush. Drain and refill is doable by the user.
Old Oct 2, 2011 | 01:58 PM
Headviking's Avatar
Headviking
That's great. So let m get this straight. We drain the pan. We remove the pan. How do we get access to the TC? Is it accessible with the pan removed? How do we turn the TC to see the plug? By hand?
Any other info would be great.
Old Oct 2, 2011 | 04:04 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The torque converter is in the bellhousing just behind the engine, ahead of the pan. There is access to the bellhousing from the bottom. You can turn the engine with a breaker bar and socket on the front pulley of the engine.
Or you could do this: Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles
curt563
Jan 30, 2010 10:07 PM
Praesul Presul
1997 - 2003 F150
19
Nov 15, 2009 06:01 PM
Selder
Dec 8, 2008 07:09 PM
cruiser_007
19
Jan 17, 2008 08:11 PM
ATC Crazy
1997 - 2003 F150
Apr 21, 2006 12:21 PM
