I hate being lost
Old Aug 22, 2011 | 04:29 PM
1977F1504X4AUBURN's Avatar
1977F1504X4AUBURN
I hate being lost
I have a couple issues and I believe they are related to timing.
1: My truck boils the radiator fluid. The heat rises gradually after 20min of driving and then fluid starts coming out of the over flow.
2: It has off idle hesitation. I can drive down the road in forth gear, mash the accelerator and it's sluggish. If I ease up on the pedal after mashing it then it will accelerate slower but a lot smoother.
Maybe I have two separate issues but I can't help but think they are related. The over heating could be caused from having the timing retarded but then the sluggish acceleration is usually a advanced timing issue. I just don't know anymore. Maybe it's a lean fuel issue.
Old Aug 22, 2011 | 04:37 PM
V10Crew's Avatar
V10Crew
Have you checked your entire cooling system? Thermostat, water pump, radiator core....
Old Aug 22, 2011 | 04:44 PM
1977F1504X4AUBURN
It has a new RT139 thermostat and the fluid is moving. I don't know how to check the radiator... it doesn't leak externally or anything like that.
Old Aug 22, 2011 | 07:57 PM
4x4 Bart's Avatar
4x4 Bart
When you floor the accelerator, does it bog then backfire through the carb? This would be a lean symptom.
Old Aug 23, 2011 | 09:42 AM
1977F1504X4AUBURN
It doesn't backfire. It bogs down then slow starts to accelerate. I have an Edelbrock 1405 so I put in stiffer step-up springs. I went to the plain ones (stiffest). If that doesn't help the power mode of the carb then I'll try different jets and rods to rich it up. I still don't know why it's getting hot. The thermostat works. I took the cap off the radiator last night and saw the fluid moving. It wasn't moving very fast though but maybe that's normal.
Old Aug 23, 2011 | 10:04 AM
V10Crew's Avatar
V10Crew
Drain your radiator and shine a light in there to see if the tubes are plugged with debris,
Old Aug 23, 2011 | 11:31 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Probably unrelated. Look down throat of carb with engine off and move accelerator. You should see the accelerator pump shooting gas immediately. The squirters clog up easily on that carb. Pulling the nozzle off there is a check ball and weight, carefull not to loose them down the carb.
Old Aug 23, 2011 | 02:27 PM
1977F1504X4AUBURN
I'm starting to think I have a head gasket out. Exhaust may be heating the coolant. I'm going to blow some are in the cylinders and check for bubbles in the radiator.
jbishop1988
Mar 15, 2015 11:25 PM
1977F1504X4AUBURN
Aug 25, 2011 12:04 AM
DKW 86
Dec 8, 2010 03:34 AM
Zorburg
Feb 27, 2004 08:07 AM
jnevin
1983 - 2012 Ranger & B-Series
Sep 18, 2003 06:53 PM
