over heating
Old Feb 23, 2004 | 08:20 PM
Zorburg's Avatar
Zorburg
Thumbs up over heating
I have a 93 f150 with a 5.0 and it is taking forever to heat up ....but when it does it over heats rapidley and then spews anti freeze all over the place .....it was even colapsing the top radiator hose also when it is hotter than H#$$ the heater still blows cold air... has a new thermostat and cap any ony have any ideas wether it would be the watter pump or head gasket??Thans for any ideas
Old Feb 23, 2004 | 08:37 PM
NascarMark06's Avatar
NascarMark06
Sounds like a clogged radiator or heater core to me.
Old Feb 23, 2004 | 10:29 PM
clstrfbc's Avatar
clstrfbc
Not to discount anything, whats easiest is often the problem.
When the Heater is not working when the engine is warm, it usually means low radiator fluid.
If the level is too low, it might not be registering on the temp gauge until it boils, then it goes off the scale.
The collapsed top hose should mean that the water radiator fluid in the engine is not high enough. ie low fluid, If the radiator was clogged it would burst the top hose, not collapse it.
Check the fluid level in the radiator when its cold, take off the cap (see warning) and look inside. The fluid should be right to the top, with spare in the overflow tank.
Warning!
Dont open the radiator when its hot!!! when the fluid is low, and its hot, it will probably let out steam, and it will burn you.
Now you just have to find the leak, if its been overheating long, it probably has several now. I would start with replacing the hoses and thermostat gasket. Inspect the water pump seal for leaks too, if the level is too low for long it will burn out your water pump too, The water pumping through it, cools it off, if there is no water, its like a garbage disposal, running and running and running.....
good luck.
Old Feb 24, 2004 | 07:28 AM
Zorburg's Avatar
Zorburg
the fluid level has been checked rechecked then checked again ...........put in all that it will take but when i turn the truck off it all comes back out
Old Feb 25, 2004 | 11:26 AM
NascarMark06
Are both radiator hoses hot, or just the top one?? If both are hot you are getting good flow, if only the top one is hot and bottom is cold, you have a blockage somewhere. I once ran into a problem on a Chrysler, where we replaced a bad water pump, with a reman, once we were all finished the truck would stll overheat. We found that the shaft on the reman pump broke as soom as we started it up, so it looked like the pump was turning, but the impeller inside wasn't moving. Just a suggestion, I'm sure that is very rare, but since it happened to me, I suppose it could happen to anyone. Keep us posted as to waht you find.Good Luck!!!
Old Feb 25, 2004 | 11:55 AM
PKRWUD's Avatar
PKRWUD
You either put the t-stat in backwards, or you have a blown head gasket. Those are the only two ways I'm aware of to collapse an upper hose. Well, using the wrong water pump would do it too, but you didn't say anything about replacing the pump recently.
Old Feb 25, 2004 | 03:44 PM
babbler's Avatar
babbler
try a new radiator cap ,just my 2 cents,my dump truck would collapse the hose and i replaced the cap and it fixed it so i would try that hope it helps..
Old Feb 25, 2004 | 06:23 PM
Zorburg's Avatar
Zorburg
I found the problem ....it was a blocked radiator after all and the fan cluch was on its way out allso ..I finally brook down and took it to a mech....a cool $500 later it should run like a ford again .lol thanks for all the imput guys
Old Feb 25, 2004 | 07:19 PM
NascarMark06
I knew it was a blockage. Happy motoring!!!!
Old Feb 27, 2004 | 07:52 AM
PKRWUD's Avatar
PKRWUD
That's great that you figured it out! Can someone please explain to me how a blocked radiator would cause the upper hose to collapse, though? I'm always up for learning! Thanks!
Old Feb 27, 2004 | 08:07 AM
hostile413's Avatar
hostile413
im with pkrwud on this one...never heard of it causing the upper hose to collapse
